HELP! Last thirdgen Camaro in republic Georgia needs help
Old Mar 20, 2009 | 04:41 AM
alienbishop's Avatar
Car: 1991 Camaro RS
Engine: In the process of swaping to 3.4
Transmission: Automatic
Hi, My name is Givi. I need help and hope that somebody here can help me. I am from republic Georgia, and I brought 1991 Camaro RS (the one and only third gen camaro in whole Georgia), but its cylinder block is craked, I have found 1991 Chevrolet Lumina apv (van) 3.1 engine, i plan to put this engine in my camaro and use on it cylinder heads and fuel injection from my engine, But i don't know will Lumina Apv engine fit Camaro or not, and what modifications will have to be done. I am sure poeple on this forum have info about that. Help to keep alive last Thirdgen Camaro in Georgia!
Thanks and sorry for my bad english
Old Mar 20, 2009 | 10:11 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: HELP! Last thirdgen Camaro in republic Georgia needs help
I'm not sure, but I think you will find the starter is on the wrong side. This is the first thing to check. You may be able to bolt your starter to the "new" engine with a bit of work, so start there.
Old Mar 20, 2009 | 10:52 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Put this in the V6 forum and those guys will probably be all over this. It may have even been covered already. Welcome to TGO.
Old Apr 21, 2009 | 02:24 AM
Car: 1991 Camaro RS
thanks for your posts!
and what about motor mounts? are they same?
Old Apr 21, 2009 | 02:30 AM
Car: 1991 Camaro RS
Thanks! could you post link to that V6 forum?
Old Apr 21, 2009 | 03:02 AM
Car: 1991 Camaro RS
I have found another engine that may fit in my car, it is 4-th gen 3.4 camaro, it is from wrecked car, but the engine is ok, but i still need adwises about swap, and infoabout required modifications, so i am counting on you guys!
Old Apr 21, 2009 | 06:19 AM
naf's Avatar
naf
Start here:
https://www.thirdgen.org/forums/v6/6...-do-3-4-a.html
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
bellez77
Sep 5, 2015 08:39 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
bjpotter
Aug 12, 2015 06:06 PM
