Wiring Harnesses!
Old Apr 15, 2009 | 08:25 AM
artemis's Avatar
Car: 1987 Camaro Z28
Wiring Harnesses!
Basically I want to know the differences in wiring harnesses between 88 V8 Camaro and a 91 V6 Camaro.
Are the interior harnesses the same?
Im betting that the engine harness is different, but maybe it isn't?
I know the 91 has air bags, so is that the only interior harness difference?
Old Apr 19, 2009 | 10:02 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Wiring Harnesses!
88 MAF and 91 SD harnesses are worlds apart, there will be alot or re-pinning to make the harnesses compatible then the matching ECM would have to be used
Any particular reason you're swapping harnesses?
Old Apr 20, 2009 | 08:26 AM
artemis's Avatar
Just bought an 88 to replace my rusted out 91. Yesterday I brought it home.... ya, the internal wiring harness is way different... and the 88 has manual windows and locks. Since I'm gonna be dropping the 91 engine in the 88, I'm gonna need interior and exterior harnesses I think.
Old Apr 20, 2009 | 11:20 PM
Pocket's Avatar
Car: 91 Trans Am
Interior options are a non-issue as far as the harness is concerned
Differences come from pinout changes and schematic changes
Why not just drop the 91 motor in and use the 88 harness on it?
Old Apr 21, 2009 | 09:10 AM
artemis's Avatar
The 88 is a V8. I'm throwing in my 3.1 and turbocharging it. I know you'll say its easier to swap in another V8, but I just grabbed everything I need for a T5 conversion for a V6. Unless I could somehow mate my 94 V6 T5 to a V8, which I dont believe you can... So i'll be dropping in the V6, so the V6 harness must be used.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
