Possible bad head gasket
Car: Firebird - Camaro
Engine: 2.8L - 6.3L
Axle/Gears: 3.42 - 3.23
So I have had my coolant "boil over" a few times in the past week.
Engine temp sensor is not going over 200-210*.
I replaced the radiator cap hoping the old one was worn out.
It boiled over again today.
I am now thinking that I have a hole in the headgasket near a water jacket which is pressurizing the coolant system and "boiling it over".
Are there any other possible ideas?
Will a compression check show this? Or do I need to do a leakdown check?
My thinking is that its a small hole, and a compression check might not show it......
help please.
help please.
Car: 86 Z28
Engine: 383 4bolt main,8504barel p&p heads
Transmission: 700R4,1800stall,shift kit,etc.
Axle/Gears: chevy posie 10 bolt
Re: Possible bad head gasket
compression test would tell u something there should b a diff. in the cylenders
Car: 86 Z28
sounds like a head gasket though
Engine: 2.8L - 6.3L
Yeah, the only thing is that it doesn't do it every time I drive the car, and other than it spilling out of the over flow, it drives fine.
Car: Many
Engine: Several
Transmission: Automatics
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
check the radiator when cool. start up the car with the radiator cap off. if there are lots of bubbles its a good indication of a blown head gasket. check the oil. might have a tint of green or red. depending on the color of antifreeze you use.
also what is the color of the smoke comming out of the tale pipe thats a good indication also.
Engine: 2.8L - 6.3L
Oil is normal, no increase or color change.
Exhaust seems normal, no tint or smell.
Car: 89 RS
Engine: 2.8
You can rent a tool at Autozone that you put over where the radiator cap fits. You pump it up to around 11 or 12 pounds. Then start the car. Pressure should come up some and hold. If pressure continues to build then you know there is a head gasket or head problem. If you return the tool its free to rent. They will tell you there how to do the test. I just gave you some basics.
Car: 91 Z28
Engine: 355
Axle/Gears: 10 bolt 3.73's
Best way to check for a blown head gasket is perform a block test, but you a block test kit to do this. I got mine from a auto parts store for about $40.
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Most likely its a bad thermostat.
Can cause engine to push water out because it is not opening at the right time.
It is easy to change and cheap!
If you have water/antifreeze in your oil, it will look like milk.
Car: 89 Firebird
Axle/Gears: ?
i agree on the radiator pressure test. but also check the level. cars tend to boil over more if the level is low. also check the weap hole on the water pump to see if its leaking.. didn't think about it.. but could be a failing water pump.
Engine: 2.8L - 6.3L
The car isn't overheating at all, could the thermostat possibly be bad?
I guess I dont understand how that could work......
Car: 89 Firebird
Axle/Gears: ?
guess so. it can fail closed. have you checked the coolant level yet?
ive seen them both fail open and closed. failing closed will cause over heating symptoms.
ambainb
Apr 25, 2016 09:21 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
