1.6 rocker arms and +.100in pushrods
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
Will I need a larger valve cover if I use pushrods that are +.100 inch longer than stock ones with the 1.6 rocker arms? Edit: Stupid question, I know, it was late at night and I was not thinking clearly. I should retake geometry.
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
Re: 1.6 rocker arms and +.100in pushrods
no, but you shouldn't need .100 longer pushrods unless you've went to a smaller base circle cam or something.
92rsvortec350
19
Oct 9, 2015 09:39 AM
