broken line ???
Old Apr 2, 2009 | 11:00 AM
sienaz 86 2.8's Avatar
Car: 86 firebird
broken line ???
ok so ive been having some issues with my 86 2.8 so to day i pulled the top half of my engine apart and noticed that one of the lines that lead to the back of the throttle body ive looked for a hour now and cant find where that line comes form and of course cant find my manual. so can any one help me out if there is even a line that goes into the thicker side of that rubber plug
Old Apr 2, 2009 | 11:02 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: broken line ???
Probably need a pic to be any help. Figure it out yet?
Old Apr 2, 2009 | 11:03 AM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Re: broken line ???
Probably need a pic to be of help. Figure it out yet?
Old Apr 2, 2009 | 12:52 PM
Car: 86 firebird
Re: broken line ???
yea i think it never had one now i finally got a check engine light code 45 claims its rich exhaust. meaning fuel in charcoal canister, malfunctioning fuel injector, high fuel pressure defective TPS, MAP, or o2 sensor. so i dont know where to begin
Old Apr 3, 2009 | 12:07 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: broken line ???
There's 2 holes in the vacuum block... is it supposed to be in the outer one or the inner one? IIRC, the inner one is ported vacuum and the outer one is manifold (full-time, non throttle dependant) vacuum. Might be backwards, though. The ported one runs the charcoal can and the EGR, and the manifold one is primarily for the fuel pressure regulator.
First, you don't have a MAP... Your car isn't carbureted or TB injected, it's got a MAF. Second, pull your plugs and see which ones aren't gray or tan, which will probably be dark sooty black. That's a good starting point. Your EGR could also be stuck.
:edit: Seems as though that broken hose is the one for the FPR... Might want to fix that to get your fuel pressure back down to 39 PSI where it belongs. Right now, if the hose is broken, the pressure is 43 PSI, and the ECM is used to the lower pressure, causing the engine to run rich based on learned calibration.
Old Apr 3, 2009 | 12:17 AM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
Re: broken line ???
sound like he is talking about the big plug in the 3 rubber plugs on the tb in the rectangle it doesn't go to anything it is a block off
Old Apr 3, 2009 | 09:39 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: broken line ???
On the 2.8, no. On the 3.1, yes. Don't know what it was for, I'm assuming either the smog pump or the evap can, but that was one of the first things I did was to switch back to my old vacuum block.
I'm still voting that the vac line running to the FPR is the one that broke and that's why he's running rich.
skeltor
Feb 2, 2016 10:37 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
camarohelp
Sep 12, 2015 05:45 PM
m00n420
Sep 11, 2015 02:39 PM
TBRays98
Sep 6, 2015 05:05 PM
