2.8 to 3.4 swap question
Old May 2, 2009 | 11:46 PM
C_D_Z's Avatar
ok I'm still new and can't seem to find what I am looking for when searching or even find threads about this.
I have read the threads How to do the 3.4 long block swap Boogie! and Dales 3.4 swap tech artical.
but I didn't see a clear answer on if you have to change any of the 2.8 wiring harness with the 3.4 harness?
if it was there I must of missed it, and sorry if this question hase been asked a million times.
Also can I bore a 3.4 and stroke it out? would I need bigger injectors or would the stock 3.4 ones work?
Thanks for any help.
Carl
Old May 3, 2009 | 01:51 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: 2.8 to 3.4 swap question
If you reuse the stock manifold/sensors you don't need to change the wiring, you can bore it out (-this is a repair proceedure, not performance-) if needed, there's no stroker cranks out there for it but you could have it offset ground if you really want to and you won't need larger injectors.
Old May 3, 2009 | 03:34 PM
C_D_Z's Avatar
thank you for answering my questions.
Old May 5, 2009 | 07:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
On the smog stealth swap, you keep your factory harness.
I have done a system where you swap the harness and ecm. Not worth the effort on an already MPFI engine.
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
92projectcamaro
Aug 6, 2015 01:20 PM
