3.4 swap
Car: 1987 Camaro
Engine: 2.8 tpi
Transmission: 5 speed
3.4 swap
hey guys i recently bought an 87 camaro with a 2.8 v6 in it. im looking to beef it up with the 3.4, i heard theyare pretty quick and tough, id go for a v8 but i need thge v6 mpg for college.
where can i find one and any comments on them?
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
The V6 forum is the better place for information on this specific swap. I'll transfer you to that department now. . .
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
Re: 3.4 swap
i too am trading my 'bird for an 89 camaro rs, and the guy has the tranny and 2.8, but the 2.8's harness is all clipped off. i found a 3.4 from a 94 camaro for a good price, complete from the computer to everything else. just wondering if the motor mounts are the same, and since the 3.4 is a 5 speed model, will it work with the 5 speed that was in the 89? i believe so, but you know the drill, ask before you do. money is tight these days!.
so basically my ? is: are 2.8's 3.1' and 3.4's all the same motor essentially, just diff bore/stroke and what not? as long as it mounts up the same and stuff, im planning on doing it till i get the 454 slapped together with the 6 speed im pursuing. any info would be great, and i already did a 3.4 swap search, but im gonna keep trying.
Car: 1989 Camaro RS
Engine: 496 BBC
Re: 3.4 swap
ah many thanks, yea it looks like ill be getting this engine in about a week. 300 bux and it was rebuilt 25k ago, with 165k total miles. not too bad. even comes with the bell housing, clutch pack, etc.
it should be a relatively painless process i think, and since im putting the 3.4 in the camaro, il take the 2.8 stuff and put that in my yota pickup, maybe do the turbo setup for it! considering ive got injectors, lots of exhaust pipe, and a spare t3-t4, ill get the BOV, wastegate, boost controller and the IC kit, and it should be a fun lil motor for a lil while neway.
thanks drdave!
thanks drdave!
Hello, Michael
Aug 20, 2015 03:19 PM
