Help identifying fuel line for fuel Pressure Gauge
Car: 1985 Camaro Sport Coupe
Engine: 2.8 - Bored/Stroked, Pacesetters
Transmission: 5 spd Manual
Axle/Gears: Stock
Any of you 2.8L V6 Guru's identify which fuel line to install a fuel pressure gauge too? Any help would be greatly appreciated!!!
The attached photo is taken from the passenger side front fender....Line 'A' or line 'B'????
Also, anybody know where I can get a replacement fuel pressure regualtor mounting screw???? Stripped by previous owner....
Car: Camaro RS
Engine: 3.1l v6
Re: Help identifying fuel line for fuel Pressure Gauge
Axle/Gears: Stock
Thanks for the reply! Im looking for which line I need to tap into to install a permanent aftermarket fuel pressure gauge. I Just installed an adjustable FPR... Sorry, I wasn't very clear with that previously. Already did the pressure testing using the Schrader valve.
Car: Camaro RS
Engine: 3.1l v6
ok no problem i will look around and see if i can find any more information for your situation
Car: Many
Engine: Several
Transmission: Automatics
one it return and one it feed ( i think). the one closest the the schrader is most likely what you want. if i had the book infront of me i could tell you. take alot of pictures hopefully it will help another member one day. good luck.
Axle/Gears: Stock
Thanks so much guys! I appreciate the guidance...this is all kinda new to me. Learning as I go.
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
