my newish 91 auto v6 camaro
Old May 25, 2009 | 10:37 PM
fendire's Avatar
hey guys im new to thirdgen... ive had my 91 camaro rs for a few months now and i love it...
so i have a small understanding on cars and what not but im no expert at all.
the idle is all over. it will idle normal, and then randomly drop down really slow and jump back up, ocasionally stalling. When the car is given alot of gas/acceleration, when the auto transmission is changing gear it will not change gear, and almost make a sound like its redlined. it wont change gear untill i ease off the gas and accelerate gently.
now i dont plan to be beating the hell out of this car, and im not a speed freak or anything, i just noticed that this is not normal, and i want a solid base and make sure its running at its best before restoring it.
thanks alot for any help and ill put up pictures and stuff soon
Old May 26, 2009 | 03:42 PM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: my newish 91 auto v6 camaro
Sounds like you have a trans problem. I would take care of that first. Adjust your TV cable(instructions are in the tech section) while your at it. Then we can try and figure out why its idling wrong. I would check the common wear out items first...have you done a tune up recently?
Old May 27, 2009 | 11:29 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
+1 for major tune up if you haven't. My old Escort had what I thought was tranny problems. but giving it new plugs, wires, coil, seafoam, oil and trans fluid, made it like new.
Old May 27, 2009 | 04:03 PM
pontiacguy1's Avatar
Definitely do a good tuneup... If you still have idling problems, then it is probably a sticking Idle Air Control Valve. I just got done reworking the heads and everything above them on my 1992 Firebird V6, including the entire ignition system (except the coil). I even took the injectors out and had them cleaned, but the car would still die sometimes when I would slow down to turn into a parking lot or something.
I changed the IAC valve, and now it idles great. It no longer dies or surges when slowing down to make a turn, or when the AC kicks on.
Old May 28, 2009 | 02:14 PM
fendire's Avatar
hey again... changed oil with 5w30 and put in high grade gas.. still same thing... will probably change plugs soon. noticed distributor was a bit loose, and when i pressed it down it bumped up and down... a screw or snap seems to be missing, thinking it could be the problem?
Old May 29, 2009 | 06:07 AM
fendire's Avatar
just ordererd a haynes manual through napa yesterday... gonna pick it up today after school... gonna check what i can... any easy suggestions to check first for a noob? get my feet wet as they say
Old May 31, 2009 | 08:45 PM
fendire's Avatar
just bought new distributor cap, rotor, spark plugs, wires, and pcv valve at auto zone for 90 bucks the whole lot. only got the distributor and cap on for now, but get this i get home from auto zone to find used distributor and cap all corroded, some douche accepted used parts as a return and i ended up getting them. haha but i came back and got new shiny ones. hopefully car will run a little smoother once i get the spark plugs and wires on there
sp8ty
South East Region
Sep 24, 2018 03:55 PM
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 2, 2015 09:12 AM
scottmoyer
Sep 7, 2015 07:06 PM
