Which Valve Springs?
Old May 26, 2009 | 01:29 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
Axle/Gears: 3.46 LSD
I'm going to be taking apart the top end of my camaro in the coming weeks. Going to add some performance, too. Well, I can't figure out which valve springs to get.
Which ones would work best (for my money) with 1.6 rocker arms?
http://store.summitracing.com/partde...0%2D12&FROM=MG
http://store.summitracing.com/partde...D84008&FROM=MG
The first one is just the valve springs with 308 lb/in.
The second is a kit with valves, lifters, and retainers; 378 lb/in.
Old May 26, 2009 | 02:11 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Re: Which Valve Springs?
Valve springs are matched to the camshaft to select, what are you installing?
-Z
Old May 26, 2009 | 02:12 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
It's the stock camshaft. Will be doing that later when I have a little more money.
I don't have much money, but the clyinder heads need new gaskets, and thought I would replace a few things, that I can afford, which I'm sure need to be replaced soon.
I was going to get the camshaft, headers, valves, rockers, pushrods, lifters, etc....but needed to spend money on something else. So now I have to pick and choose. Still doing price comparison.
Old May 26, 2009 | 09:07 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
What about with this cam, or one with similar specs like from Delta (since they are cheaper in price)?
http://store.summitracing.com/partde...TC%2D5&FROM=MG
I'm trying to budget build this. I don't need an over the top performance, just a little more "go" for a little more mpg and excitement in daily driving (ie: corners/on ramps).
Any help will be much appreciated.
Old May 26, 2009 | 11:47 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Originally Posted by d00012
Seems too close to stock IIRC.
If I'm going through the *** pain of a cam swap, I'd spend $30 more for a noticable difference.
http://store.summitracing.com/partde...4&autoview=sku
Old May 26, 2009 | 11:57 PM
d00012's Avatar
Car: 2006 GTO
Engine: LS2
Transmission: M6
I haven't decided on which cam yet, i'll probably have Delta make a custom one for me. Calling them tomorrow and see what springs, lifters, etc they have/recommend, and check their pricing.
But it says that comp cam isn't computer compatible. Need 112 lob separation, don't I?
pjsparts
Oct 29, 2025 06:39 PM
crzycamaro86
Sep 12, 2015 05:51 PM
ericjon262
Sep 11, 2015 06:07 PM
lakeffect2
Sep 7, 2015 03:52 PM
