No spark to 92 3.1 camaro
Old Jun 15, 2009 | 10:57 AM
new324's Avatar
She was falling on her face when heated, replaced cap, rotor, plugs, and wires. Idled her warm, and touched the ignition coil and it died.
Replaced coil and she ran like a striped ape for a thousand miles, well, after I fixed the muffler that exploded during the not so pleasant times.
Then she died last week, and its not getting a spark to the distributor. Replaced distributor with a decent junk yard part, which had a better looking copper coil, and I still don't get a spark when I crank the engine. Salvage man is a good friend of mine, and the engine was running when they pulled it a few years ago.
Any ideas?
Old Jun 15, 2009 | 11:13 AM
JJx91camaro's Avatar
Car: 1991 chevy camaro rs
Engine: carbed 350 sbc
Transmission: th350
Re: No spark to 92 3.1 camaro
is the coil atleast putting out a spark?
Old Jun 15, 2009 | 12:40 PM
new324's Avatar
The coil is good, we used one we knew was working since the latest break down.
I did stumble on an old thread that said to check to see if the rotor is spinning while cranking and sure enough, it wasn't.
Anybody have any pdf literature on swapping a timing chain?
ty ty ty
Old Jun 15, 2009 | 02:04 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Get a haynes manual, itll tell you what to do and torque specs, all that good stuff. theyre not the greatest thing in the world, but itll walk you thru what you need for that job. BTW, make sure its the chain, it may be a broken cam too, not as likely, but still a possibility.
Old Jun 15, 2009 | 04:01 PM
new324's Avatar
I have one already, but its at home. I had a roomie read me the section over the timing chain, so all should be good. I gave up finding a pirated copy online.
Ty though!
Old Jun 15, 2009 | 04:40 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
well did you take the rotor shaft out and check it because that happen to me the gears or whatever in the shaft just chewed themselves to pieces
Old Jun 20, 2009 | 07:17 PM
new324's Avatar
I put in a different distributor so I don't think that would have been the issue. I'm going to replace the timing chain Monday when my mechanic can supervise, I'll post results.
92camaroJoe
Jul 29, 2023 07:57 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
92camaroJoe
Aug 13, 2015 06:07 AM
the_nikfive
Aug 11, 2015 02:46 AM
