rich o2 sensor code
Old Jun 17, 2009 | 08:02 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
rich o2 sensor code
getting a rich o2 code. what could be causing it?
Old Jun 18, 2009 | 08:28 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: rich o2 sensor code
Bad O2 sensor, stuck injector, excessive fuel pressure, crapped out (or crapping) maf...
Old Jun 19, 2009 | 12:27 PM
enswrob's Avatar
Car: 89 Firebird
Axle/Gears: ?
time to unplug the maf and see if the car runs better...
guess ill have to check the injectors also.
Old Jun 20, 2009 | 10:28 PM
bl85c's Avatar
Car: '85 maro
Unplugging the maf won't tell you anything. It reverts to 'limp home' mode which makes it run extra rich. Use a mechanic's stethiscope to listen to the injectors.
antman89iroc
36
Jan 31, 2016 08:42 AM
Luigytico09
Oct 1, 2015 08:46 AM
James Sutton
Sep 23, 2015 02:18 PM
Shane87irocz
Sep 22, 2015 06:21 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
