2.8 runs again....
Old Jun 17, 2009 | 03:29 PM
mongoosekeith's Avatar
2.8 runs again....
.....kinda, i finally figured out what was wrong with the 2.8 in my 88 RS the coil, cap and rotor were bad, the reason i didnt check this before now was the po had said he replaced them not to long ago. But now the car will not idle until it is warmed up, and when you rev it to fast it backfires into the intake hard enough to lossen the speed fasteners on the air filter cover. Could this be a timing issue or bad ECM or bad idle air or a combo of all of the above. The car also will not go into reverse, it will lunge a little but will not move back idk what is going on. Any sugjustions would be greatly apprreciated.
Keith
Old Jun 17, 2009 | 06:04 PM
83z28camaro's Avatar
Car: '01 GMC Sierra
Engine: 5.3L
Transmission: 4L60e
Axle/Gears: 3.73 eaton locker
Re: 2.8 runs again....
The first problem sounds lean or timing issue. Is it a stick or auto. if it is auto will it go forward in neutral?
Old Jun 17, 2009 | 06:23 PM
it is an auto, and no it wont go forward in neutral. Now has a bag knock in the bottom end of the motor. Probably going to build a new motor.
Old Jun 19, 2009 | 10:04 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Hey mongoosekieth?
Does your name have anything to do with mongoose bikes?
Old Jun 20, 2009 | 09:16 PM
yes sir it does.
Old Jun 20, 2009 | 09:23 PM
snowman383's Avatar
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
gave up the bike for a car huh...
Old Jun 21, 2009 | 01:08 PM
hahaha ya. tired of having to ride everywhere lol. ok i no longer need a motor as i am going to pick one up next weekend form Louisiana. BUT i still need a transmission for my car. having no reverse really SUCKS! i need to know what trans the car has in it does anyone know?? It is an 88 camaro with the 2.8 and auto. I have heard it is the 400r or what ever but i need to know. i am to thick in the middle to slide under the car and look for tags and to lazy to jack it up
Old Jun 21, 2009 | 01:30 PM
snowman383's Avatar
Engine: 350 crate
can get a tranny at u pull it here where i am at...they have a few cars and trucks with a 2.8 so the tranny will be the same..just need to measure the length of it
Old Jun 21, 2009 | 08:25 PM
Schwinny's Avatar
Car: 1987 Firebird
Engine: 2.8l V6
Sweeet.
I used to have a Motomag.
eightsixseven
Dec 16, 2024 01:50 PM
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
perZ
Aug 21, 2015 05:51 PM
86Base
Aug 8, 2015 01:34 PM
