acceleration
Old Jul 22, 2009 | 08:25 PM
evol's Avatar
Car: 1991 Z28 camaro
acceleration
Alrighty, I got a 1991 camaro rs and i just replaced the plugs(previous owner didnt put matching ones in)and plug wires cause one was broke...now my first ? is do the lengths of the wires matter to which plug they go to...I put them in the correct spots...and with that would that affect the acceleration
When i step on it it revs way up and seems like i gotta let off then step back on it for it to go or takes awhile to catch on
Old Jul 23, 2009 | 09:42 AM
mtwlkn122's Avatar
Car: 91 Firebird, 06 Dodge Ram 1500 SLT
Engine: 3.1L, 4.7L
Transmission: 700r4, 45RFE
Axle/Gears: 3.23 open, 3.55?
Re: acceleration
Length does matter in a dyno/mathmatical way....but are you going to notice it in the "seat of your pants" NO. Make sure those plugs are on in the right order on the cap(refer to Hanes manual)...the way you describe it "...revs way up and seems like i gotta let off then step back on it..." it sounds like you have a transmission problem. Check your trans fluid to make sure your at a good level. A 700R4 will cook the higher clutch packs REAL FAST if you run down on fluid. Pretty much you will end up with first and second...which is fun if your live in a town with only a 30mph zone but its not fun anything more then that and also puts alot of wear(heat) on your tranny and will also kill your mileage.
Old Jul 23, 2009 | 12:07 PM
LTPMarine's Avatar
Re: acceleration
It sounds like u have a transmission problem. Check your fluids.
Old Jul 23, 2009 | 08:00 PM
evol's Avatar
Re: acceleration
Heh wow dunno how i even missed it...it was pratically empty, i dunno for how long either...i filled it back up took it out for spin and still there...what to do next?
Old Jul 23, 2009 | 09:22 PM
sloick's Avatar
Car: Many
Engine: Several
Transmission: Automatics
Re: acceleration
pray.
then look for a metric 700r on craigslist.
Old Jul 24, 2009 | 01:11 PM
mtwlkn122's Avatar
Engine: 3.1L, 4.7L
Re: acceleration
Originally Posted by sloick
pray.
I like that
....ya if you added fluid and it still is doing it you burned out the clutches...time for a rebuild....give theses guys a shout....if you have to rebuild mind as well rebuild it for some fun times right?....check this link...
https://www.700r4l60e.com/store/home.php?cat=19
^^they make amazing kits for our transmissions...personally i am just waiting for my transmission to break so i can do one...seeing how i check all my fluids and such just about every weekend (i know im ****, its my baby what can i say lol) i doubt it will go anytime soon
Pac J
May 17, 2020 10:44 AM
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ULTM8Z
Sep 16, 2015 09:15 AM
