The End Is Near!!! (er)
Old Nov 17, 2010 | 04:06 PM
  #51
overide's Avatar
Re: The End Is Near!!! (er)
Nice... this is something I'm batting around. I want to go with the 3.4 rwd bottom end and 3500 topend.... I wish you had some dyno numbers... I would love to know what its putting down to the wheels... You port the 3500 plenum at all? How come you did not go with 3500 heads? Is it because of the header issues?
I've seen alot of flow numbers on the stock 3400 & 3500 heads, but no numbers on a ported set... makes me wonder what they are truely capable of. Is the 3400 and 3500 plenum portable? Sorry you just got my mind going....
Old Nov 17, 2010 | 09:53 PM
  #52
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Ya, I had wot tech do the lim and firstfirebird do the plenum. They were actually pretty close to each other and I only had to do minor touchups to get them matched. I've put several combinations of parts on this motor to see what does what individually. I haven't had time to mess around with the latest combo too much, but according to my software the stock 2.8 cam, unported 3100 upper & lower manifolds and 56mm throttle gave me 180hp (that's 215hp at sealevel) with 9.36 cr. Swapping in the roller cam (220/225 duration) gave me 210hp (250hp sealevel), didn't see any more peak power from the 65mm throttle but interestingly low to mid torq improved, and the 3500 plenum and unported lower gave me about 215hp (260hp sealevel). I'm guessing the ported lower gave me another 10hp and when I get 3500 heads I'll be in the 300hp range. Glad I spent the extra money on reuseable lim gaskets. So far I don't have any reason to doubt my software because it's pretty damn close to what I was calculating based on track times.
Old Feb 18, 2011 | 02:16 PM
  #53
Blue1990camaro's Avatar
thats a badass project bud, i wana do something very similar to my 90 rs, being i hav n 89 z24 i built. lol.
now how did u over come the ignition isue i cant seem to figure it out? my 3.1 uses a distributor, form what i see, your using the ign module and coil packs from a 3400? what computer and harness are you using? all 3400? im pretty familar with FWD setups cuz iv looked into it for my z24, but the conversion in my camaro seems far more complex, lol, help a fellow v6 thridgener out? lol
thast awsum tho, it really is, its wicked cool to say ur v6 camaro can blow an iroc z28 outa the water lamo
Old Feb 22, 2011 | 08:02 PM
  #54
bl85c's Avatar
Car: '85 maro
Thanks, I've always loved odd engines- especially those with potential. Wait till I finish the twin turbos. The ignition is from a 3400 and I'm using a modified version of 6E on a '165 ecm to run it. Here's some links. DIS and ECM.
Old Aug 18, 2011 | 06:18 PM
  #55
bl85c's Avatar
Car: '85 maro
Oooh goodies waiting to go on! If only I had the time to do it!!!
Old Aug 26, 2011 | 01:38 AM
  #56
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
do it.........and soon i love this build thread, got any numbers as far as hp yet?
J-money
Jan 4, 2019 09:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
dbrochard
Sep 7, 2015 09:41 AM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
