Ya think I got a leaky injector?
Old Oct 10, 2009 | 09:37 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I had a new fuel pump put on a month ago. I put a fuel pressure gauge on the schraeder valve and turn the key and got 48 psi and then started the engine and got a steady 46 psi while running. I turned the car off and the psi dropped to about 30 psi in 5 minutes. Leaking injector(s)? New FPR too.
Ken
Old Oct 11, 2009 | 07:30 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Ya think I got a leaky injector?
Leaving the pressure gauge hooked to the test nipple, find a way to SAFELY clamp off the fuel hoses. If you clamp the larger one and the pressure holds, there is a problem with the anti-drainback valve in the fuel pump. If you clamp the small one (only) and the pressure holds, the FPR leaks. If you clamp BOTH and the pressure still drops, then the injectors are leaking. The system SHOULD hold pressure for 20 minutes, at least, without losing more than about 2 PSI of pressure.
Old Oct 14, 2009 | 06:15 PM
ken3983's Avatar
Well pinching the fuel lines didn't change my psi drop. I'm thinking its the injector(s). Even while driving, my scanner shows the block learn AND the integrator at 100. Sometimes at idle, the integrator will drop to 90 and sometimes in the 80s. Funny how the ECM does'nt throw a code or anything. Still, it could be a vac leak I have'nt detected yet. Can't you pull the fuel rail out and have someone turn the key to see if you got a leaking injector?
Ken
Old Oct 16, 2009 | 12:36 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
Yep. Undo the Fuel line hold brackets, take the upper plenum off, remove the rail and injectors, and set the rail on something with the injectors hanging from it so you can see them dripping.
I had mine sitting on the radiator all hooked up (minus the fuel injector wire connectors) The system primes right up and you can watch each injector for leaks.
The few times I lost pressure was from a bad cold-start injector o-ring after I installed it wrong I guess, and the rail itself was bad (wouldn't seal against the pressure regulator disk or whatever)
*did have a leaking injector once. I installed my old injectors while the rail was out instead of pulling the new injectors out of the intake. Had one that leaked slightly. Still didn't account for the 35psi drop in 10 seconds.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
