Underdrive Pulleys
Old Dec 7, 2009 | 10:18 PM
drewman_93's Avatar
Car: 89 Camaro
Engine: 2.8 V6
Axle/Gears: 3.42 open
Underdrive Pulleys
anybody put underdrive pulleys on? notice any difference in power or any adverse effects?
Old Dec 8, 2009 | 07:38 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Underdrive Pulleys
I have the crank pulley, not really worth the $60 it cost me. If you can find one cheap, maybe pick it up, but i didnt really notice any difference. If youre running any sort of a sound system, dont do the crank and alternator, you may run into charging problems.
Old Dec 8, 2009 | 05:44 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Crank and Alt pulleys here. Didn't notice a big difference if any at all. My problem now is my AMP gauge dips below 13v when sitting idle, all lights get dim. I've put in a new battery and a new alternator and it still does that. I do however still have my ground wire and another wire hooked to my radio when I had my system in the car. Doubt that's causing the problem tho.
Old Dec 8, 2009 | 09:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I've got the crank and alt pulley and have a small amp. Never had a problem.
Old Dec 8, 2009 | 09:45 PM
drewman_93's Avatar
Car: 89 Camaro
Engine: 2.8 V6
thanks. i'll take that as a not worth it.
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
