can a Tach be out of calibration?
Old Dec 23, 2009 | 10:01 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
the RS V6 I got yesterday does something odd. When I shift (very conservative, no hot rodding) the RPM's almost get to the yellow area, and when going 60-65, the tach is between 3250 and 3500. The engine doesn't SOUND like it's revving that high
can these things be off?
Old Dec 23, 2009 | 10:24 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: can a Tach be out of calibration?
Short answer: Yes, the tach can be off.
Long answer: There are 2 primary causes for this... The first is age. There can be interference on one of the ignition module's circuits that can "create" reference pulses on the line, creating a false signal to the tach. About the only way to verify this is to physically look at the ECM's reported engine speed.
If you have a T5 (and it sounds like you do), and you have the standard rear end gear that was given to the V6 (3.42 as reported by the TGO 1992 data page), you should be running around 2030 RPM at 60 MPH.
Old Dec 23, 2009 | 10:27 AM
58mark's Avatar
I would say that's what it sounds like to my ears. I'm not worried about it, but it's a little troubling to see that tach go all the way up to 5000 during normal shifting
Old Dec 23, 2009 | 10:41 AM
flu_by_u's Avatar
Car: 1989 Firebird Formula
Engine: 350 5.7L TPI
I'snt there a resistor on the circuit board that loses its value with age? I an article somewhere on hear on how to find the value. I have to look for it again.
Old Dec 23, 2009 | 11:37 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, the thread is on the electronics board. Rather long IIRC.
RBob.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
