It went from working fine, to fuel pump wont prime... In no time
Old Jan 15, 2010 | 02:05 PM
dontellmymom's Avatar
Car: 1990 Firebird
Engine: 3.1....4159265
Axle/Gears: axle rose and metal gear solid
Everything was working fine except I had a small water pump leak.
So I replaced the water pump and now when I try to start her up the fuel pump does not kick in like it used to.
She does crank very nicely.
Can anyone think of anything that I might have damaged while replacing the water pump?
-1990 V6 3.1 Firebird
"From working fine, to will not prime, in no time!" (I should have been a rapper...)
Old Jan 17, 2010 | 03:34 AM
Car: 1990 Firebird
Re: It went from working fine, to fuel pump wont prime... In no time
To whom it may concern:
I fixed the fuel pump issue. My fuel pump became disconnected and the harness was laying on the top of the rear differential. I still don't know how the fuel pump harness came undone because I was working on the water pump and it is nowhere near the fuel pump. I backed the car into my garage weeks (apparently the fuel pump just happened to disconnect itself inside my garage after I put it in park!) ago to start working on the water pump.... im going to chalk it up to an ACT OF GOD.
H-TOWN
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Kaweh
Aug 9, 2015 02:54 PM
