SPID Labels... Let's see some!
Old Jan 28, 2010 | 01:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I'm sure I'm not the only V6 guy on here who is missing their Service Parts ID label that is SUPPOSED to be either inside the console door or the door to the rear glove box. I'm trying to put mine together so I can get a replacement from an aftermarket supplier (since GM saw it fit to destroy most of the pre-90 data sheets). Does anyone here with a pre-90 V6 still have their sticker? I'm trying to figure out the codes for the VSS and gears, and the generic code for the rear axle. I can get the spring codes off of my spring labels (if the rears still have theirs, I don't remember if they do or not), but that still leaves the VSS, gears, and the rear axle. Most of the pics I've seen in the History/Restoration forum are for post-90 V8 TransAm's and GTA's...
Old Jan 28, 2010 | 03:09 PM
87v6Bird's Avatar
Car: 87 Firebird, 89 Trans Am
Engine: 406, LB9
Transmission: T56, 700R4
Axle/Gears: 3.23 Torsen, 2.73 Posi
Re: SPID Labels... Let's see some!
Here's mine.
Hope it helps!
Old Jan 28, 2010 | 03:44 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Originally Posted by 87v6Bird
Here's mine.
Hope it helps!
I hope you didn't tear that out of your car.
Can you clarify some of the codes? The 2 codes after AAA are a little fuzzy.
Old Jan 28, 2010 | 05:33 PM
87v6Bird's Avatar
Engine: 406, LB9
No I didn't tear it out haha. It had actually fell off and I was afraid it would accidentally get thrown away so it's now in a safer place. The codes after AAA are AK1 and AR9.
Old Jan 28, 2010 | 06:32 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Some double-sided tape will fix that right up. Do you have the optional GTA interior?
Old Jan 29, 2010 | 08:29 AM
87v6Bird's Avatar
Engine: 406, LB9
Well I don't know what that is for sure but I highly doubt it. My car is about as basic as it gets. No power locks, power windows or hatch release. Nothing but a speedo, fuel gauge and dummy lights in the cluster. About the only options I think it came with are AC and a radio with cassette player and neither of those worked by the time I got it .
puma1552
FAQ Board
18
May 20, 2017 10:07 AM
puma1552
Feb 17, 2012 10:23 AM
mr396
Apr 29, 2010 09:56 AM
kizz
Feb 27, 2003 12:06 PM
