engine missing firing?
Old Feb 28, 2010 | 08:55 AM
tic_tac's Avatar
Car: 1989 Camaro RS
I have a problem and I'm hoping some one will be able to help me figure it out. The problem is that what seems to be random times when I'm driving, be it on the highway or just in the city. When I give the car gas it will sputter like it doesn't want to go. But other times it does fine. It also will be doing fine going down the highway at a steady speed until I give it a little more gas and it will start to sputter.
I haven't checked for all codes yet, I'll try and get to it today and post what I find. I was just wondering if anyone had anything I should check out or advice. The plugs were replaced last summer along with the fuel filter.
Thanks in advanced for any help you guys.
Old Feb 28, 2010 | 10:33 AM
kubinusa's Avatar
Car: 1985 Camaro
Engine: 2.8, V6
Transmission: automatic
Re: engine missing firing?
It might be bad ECM, I had the same problem, sometimes it worked fine and other time it was causing misfiring problems along with other issues at some point, later I coudn't get any codes out of it, not even code 12. It might be some other sensor like TPS, see if you can get any codes
Old Mar 1, 2010 | 11:27 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
If you have a tach, does it jump when the engine is misfiring? That's an indication your ignition module needs to be replaced BEFORE it leaves you stranded at the side of the road. Also, have you checked your spark plugs' color? And yes, any codes would help.
Old Mar 1, 2010 | 11:39 AM
kubinusa's Avatar
Car: 1985 Camaro
Engine: 2.8, V6
So bad ignition module causes the tachometer jump? Cause mine was moving up and down within 10mph while driving, had the ignition module checked at autozone, not sure if I should trust them with it, the guy didn't look too sure about what he was doing, had the misfire problems as well
Old Mar 1, 2010 | 11:55 AM
Engine: 2.7L V6
Axle/Gears: 4.41
The tach (RPM x1000), not the speedo. The speedo jumping is an indication that you need either a new cable or cable gear in the transmission. The ICM failing doesn't always cause the tach to jump, but it can and I've seen it do so (2 weeks before it failed on me).
Old Mar 1, 2010 | 02:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Is not the '89 MY when GM started to use the wonderful Multec injectors?
RBob.
Old Mar 1, 2010 | 06:24 PM
Engine: 2.7L V6
Axle/Gears: 4.41
RBob.
Don't know about 88 and 89, but in 87, the parts sites list 2 injectors for the 2.8, the pintle cap 523-5210s, and the Multitec 523-5136 injectors, back when GM was still using the RP 7 digit ID codes. I'd guess that 87 was the crossover year?
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
