problem with lean exhaust and sputtering help?
Old Feb 28, 2010 | 11:52 AM
Jbeal57's Avatar
Car: 91 rs camaro
Engine: 3.1L V6
My 1991 rs camaro 3.1L v6 has been running rough for the past few months in the winter. It has been sputtering alot until it is completely warm. sometimes a lean exhaust code comes up but doesnt stay on long. i changed my O2 sensor and my air intake and air filter. also a few times i have started it up and it pretty much just dies and just cranks but wont start. i need some help figuring out this problem thanks.
Old Feb 28, 2010 | 12:09 PM
aks's Avatar
aks
Car: 92 Z28
Re: problem with lean exhaust and sputtering help?
what's your fuel pressure at? cuz clearly your not getting enough fuel in the cylinders.
Old Feb 28, 2010 | 03:21 PM
Jbeal57's Avatar
Car: 91 rs camaro
Engine: 3.1L V6
last time i checked it was okay. ill have to check it again ill let you know.
Old Feb 28, 2010 | 04:25 PM
Jbeal57's Avatar
Car: 91 rs camaro
Engine: 3.1L V6
my fuel pressure at the rail is 42 pounds. would you think it could be a bad vacuum line?
dyeager535
Aug 28, 2015 08:10 AM
db057
Aug 22, 2015 08:17 PM
gta power
Aug 13, 2015 06:15 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
