My 3.5 swap project...
Old Jul 4, 2010 | 10:55 AM
  #101
Fallen2603's Avatar
Car: 2006 Cobalt SS/SC
Engine: LSJ
Transmission: F35 MU3
Axle/Gears: 4.05
Re: My 3.5 swap project...
Just with degreaser?! DAMN...LOL!
You're going to repaint it that same color though, right? That way, someone might mistakenly think that it's a BIG BLOCK! LMAO!
Old Jul 4, 2010 | 12:05 PM
  #102
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
lol... if i can get some new media for the blast cabinet i might just glass blast it then paint it with clear engine paint.
I was going to use the chevy orange for the block but black hides grease and dirt better.
Old Jul 5, 2010 | 10:40 AM
  #103
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Yeah, can't say which I'd go with. Sometimes, seeing oil/fluid leaks easier can be a good thing. Unless it's going to be a show car...
Old Jul 5, 2010 | 10:43 PM
  #104
Engine: 450HP 355
Transmission: TH350
Here is a pic of the front ride height after i cut 1.5 coils from the springs.
i have the springs indexed 180 degrees out right now, it'll probably drop another half inch or so once i move them back to the stock spots.
pretty much down to plumbing and wiring now.
Old Jul 5, 2010 | 10:54 PM
  #105
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Put the Grim Reaper hood back on I see...
Old Jul 13, 2010 | 12:38 AM
  #106
Engine: 450HP 355
Transmission: TH350
Ok, i modified some 4th gen accessory brackets and had to do some more work to the timing cover and the water pump but the accessory drive is all figured out.
FYI, the 4th gen PS pump bracket is pretty neat, it's got a mounting pad for the DIS module and coils which puts it in a very handy spot.
The wiring is a mess right now, the drivers side bulkhead is still all stock Camaro but i snipped out and yanked what was left of the old 2.8 ECM harness and replaced it with the 3.1 harness from my 91 Z24. in the next few weeks i'll finish up the wiring and deal with the other random problems that are coming up.
Sadly it's not going to make it to the dyno this friday, i'll just have to spend my time tuning everyone elses stuff instead.
More pics and updates soon.
Old Jul 13, 2010 | 01:22 PM
  #107
Awesome-X's Avatar
Car: 87 Camaro
Looking forward to them! Hope you get it situated soon
Old Jul 13, 2010 | 09:08 PM
  #108
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Looking good so far !
Can't wait for those pics either... I hope you get some good ones of how you got the 4th gen brackets to work.
Old Jul 13, 2010 | 11:04 PM
  #109
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
Old Aug 4, 2010 | 08:45 PM
  #110
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Any updates?
Old Aug 5, 2010 | 12:49 AM
  #111
firstfirebird's Avatar
It's easier than modifying the 3.1 brackets
3.1, the alternator bracket will hit the TB, and a lot more drilling is required, with the 3.4, it's almost direct, you will just lose 2 bolt holes in the whole swap, some bent metal will take care of it, but honestly - why do you need so many? I eliminated the third member of accy's on dozens or cars with various engines, and never had a problem or warranty call for one. Working in a machine shop for the past several years has giving a new understanding on how mechanical (and electrical) devices work.
3.1...
http://i158.photobucket.com/albums/t...d/100_3773.jpg
3.4...
http://i158.photobucket.com/albums/t...lscar005-3.jpg
Old Aug 5, 2010 | 07:14 AM
  #112
Engine: 450HP 355
Transmission: TH350
Originally Posted by RSFreak
Any updates?
I'm hoping to get back to work on it this weekend, pretty much wiring and plumbing left... probably going to have to buy a V6 radiator as well but that's ok...
Old Aug 5, 2010 | 07:39 PM
  #113
Engine: 2.7L V6
Axle/Gears: 4.41
3.1...
3.4...
Still have to enlarge the bolt holes on those buggers to match the new heads, right? Guess I could sell off some more aluminum brackets. BTW, what headers are on that engine with the 3.4 brackets on it?
Old Aug 7, 2010 | 10:37 PM
  #114
Engine: 450HP 355
Transmission: TH350
Got about 80% of the wiring done and finished up the alternator and PS pump brackets today. Also got the TCE external trigger mounted, just need to space the brackets out 1/4" to match the crank pulley.
Combining the 91 Cavalier ECM harness with the '89 Camaro body harness turned out to be a lot more work than i thought. Most of the wiring is the same colors however the injector wiring is routed a completely different way. The Fuel pump relay and OPSU wiring was a bit different as well. I ended up using the Jbody setup instead since it was intact.
The only major thing left to wire is the radiator fan relay and the fan itself, still need to pick up a V6 radiator so that can wait. Wire loom will come when everything is in it's place.
I just happened to look underneath the car today and noticed that the Hooker catback has terrible ground clearance now that the front springs have settled. I think i'm going to have to pull out the I pipe and cut a few inches off of it to try and tuck it closer to the car. I have maybe 2" clearance right now.
Here is a current pic.. the wiring may look like a mess but it's all where it needs to be, most of it will be fairly hidden once the new upper intake is on.
you can see how i sandwiched the TCE trigger wheel between the crank pulley and the dampener, this version of wheel's design required me to drill through one of the spokes for one of the 4 pulley bolts. At least now there is no chance of it spinning behind the pulley.
Old Aug 14, 2010 | 03:45 PM
  #115
Engine: 450HP 355
Transmission: TH350
Things just got a bit more interesting....
Old Aug 14, 2010 | 04:24 PM
  #116
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
LOL! DAMN...where the **** did you get those?! That looks ****ing SWEET!
Old Aug 14, 2010 | 04:52 PM
  #117
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
ummm...wow! sweet. lol
Old Aug 14, 2010 | 07:14 PM
  #118
Engine: 450HP 355
Transmission: TH350
These should perk it up a little more. I had to make up for the extra power loss of the auto trans somehow.
They came from Marc at TCE, This is currently the only set but he may be making more someday. Tuning is going to be fun for sure. There is a balance tube that goes between them that's not pictured, i may try to engineer something with a little more volume though. It all depends on how the MAP signal looks.
Old Aug 14, 2010 | 08:51 PM
  #119
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Ooo, shiney stuff.
Old Aug 15, 2010 | 09:41 AM
  #120
Originally Posted by Purple82TA
Here is a current pic.. the wiring may look like a mess but it's all where it needs to be, most of it will be fairly hidden once the new upper intake is on....
Ummm, you got some hiding the wire to do :P
Old Aug 15, 2010 | 01:35 PM
  #121
Engine: 450HP 355
Transmission: TH350
lol, that was a test fit.
I still have to port the adapters out to the 3500 gaskets, but now i know where the IAC and TPS will be so i can start looming everything.
Old Aug 16, 2010 | 05:21 PM
  #122
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Just a thought here, but I wonder if that alternator could be moved down lower on that bracket where I'm guessing the A/C condenser was, there is a lot of weight sitting pretty high on that current setup.
Also not the ideal place to ask but I figure you know the answer purple T/A, what is the third wire on an alternator for and how do I switch from 3rd gen 2 wire to 4th gen 3 wire alternator? I swapped in a 3.4 and am going to use the serp setup instead of the multi v belts.
And that plenumless intake is beast,lol-you know that thing is going to have bad streetability like that right? Course that wouldn't stop me...how much did it run if you don't mind my asking, I've thought about trying to find one before but figured I would have to have one custom made, would be cheaper if someone already has one designed.
Old Aug 16, 2010 | 06:58 PM
  #123
slowmaro87's Avatar
Car: 1982 z28
Engine: 400
Axle/Gears: 3:23
congrats you have the first V6 to make me envious
KUDOS man that looks killer!
Old Aug 16, 2010 | 07:47 PM
  #124
Engine: 3.8, 3.4
They really do,lol not sure what hood one would use with the plenumless intake though.
Old Aug 16, 2010 | 10:50 PM
  #125
Engine: 450HP 355
Transmission: TH350
This one...
as for the alternator, it is pretty high on the engine but works for now. I do plan on making some new brackets someday but for now it does the job.
that bracket and alternator are from a 4th gen, the plug just had 1 wire coming out and of course the terminal in the back was hooked up normally. I've got the old plug from my Jbody alternator in it now which is a 3 wire. I haven't wired it in yet. When i do i'll post the details.
I'd rather not post the price of the ITB's but i will say they weren't cheap. I think first_firebird was working on a cheaper alternative out of production pieces. Maybe he can comment on that.
It shouldn't be too bad to drive on the street, i'm more worried about the 3500 stall than the intake. lol
Old Aug 16, 2010 | 10:53 PM
  #126
Engine: 3.8, 3.4
Actually yeah, I guess cowl would be the way to go for that, since it has the filters on top like a carbed car, and yeah, I recognized the bracket and alternator :P When you say you just have one wire coming out, you mean the 2 wire plug style and just left the one pin not connected to anything? kind of like plugging in a 3 prong electric cord into a 2 prong extension cord backwards? What does the 3rd wire do...cause I honestly have no idea...
And what size cowl is that? I'm guessing a 4 or 5"?
Old Aug 16, 2010 | 11:02 PM
  #127
Engine: 450HP 355
Transmission: TH350
I'm working on a sheet metal filter box that will bolt to the stacks and seal up to the hood when it's closed. The plan is to use a 4th gen K&N aimed at the back of the scoop. It should work out pretty well.
I'll get a pic of the alternator plug tomorrow after work.
It's a 4" Harwood bolt on hood.
Old Aug 16, 2010 | 11:23 PM
  #128
Yeah, Marc made those from billet aluminum, no where near cheap :P
I have an idea, but first we want to release the 3400 swap kit for the f-bodies we will be having some new intake designs this year, should be interesting for the carburated guys
Old Sep 11, 2010 | 10:36 PM
  #129
Engine: 450HP 355
Transmission: TH350
Thanks to Pillsbry10 i now have the accessory drive complete. He hooked me up with a proper PS pump pulley.
I don't have any new pics but the alternator bracket is now lower and basically in the stock 3.4 location. I modified a spare 7x trigger wheel and bolted it directly to the dampener so now the crank pulley isn't spaced out 1/8". This solved a bunch of issues.
Last weekend i replaced the fuel lines with a good pair from an 88 Z28 at the junk yard and installed the proper VSS. Still left under there is the torque arm mount to fix and i'm going to swap to a 1 piece trans crossmember with some extra clearance made for my exhaust.
Up front is some fuel line routing, hooking up the 4th gen lower radiator hose and finding one for the upper, then a little more wiring work.
It's coming along slowly... i'd still like to hear it run before winter.
Old Sep 11, 2010 | 10:40 PM
  #130
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
no problem if you need any other random parts the junk car is still in my garage(minus the front bumper cover as of tonight)
youll probably have yours running by time mine is painted...in 2 years
Old Sep 20, 2010 | 07:17 PM
  #131
moparboy242010's Avatar
thats pretty cool... i like the k-member. Ive heard of people doing this swap, also in s10's. my roommate is a big fan of the 60 degree... he owns a 3500 turbocharged fiero, you might know of him from the v6z24 site. he had a cavalier also.
Old Sep 20, 2010 | 07:34 PM
  #132
Pillsbry10's Avatar
any updates?
Old Sep 20, 2010 | 09:34 PM
  #133
Engine: 450HP 355
Transmission: TH350
Not really much happening, i started working on a custom trans crossmember to gain some exhaust clearance but that's about it.
I might end up looking for some stock V6 front springs, mine were in pretty bad shape and now that they have settled i don't think that i'd clear a speed bump. haha
I have another project that i need to take care of for a while, gotta finish building a mild 3400 to put in my old '91 Z24 so the new owner can pick it up. I also need to put the trans together, the interior back in the car and find a wiring harness. All before November 1st.
Old Sep 20, 2010 | 09:46 PM
  #134
Engine: 2.7L V6
Axle/Gears: 4.41
Just pulled mine out a few days ago. Too high for my tastes, with me no longer having A/C or an auto transmission. LMK if you want a pair. They're a little rusty, but the factory P/N and ID tags are still there (BXR).
Old Sep 20, 2010 | 09:54 PM
  #135
Engine: 450HP 355
Transmission: TH350
How well do the aftermarket ones sit on the V6 cars?
Old Sep 20, 2010 | 09:56 PM
  #136
Engine: 2.7L V6
Axle/Gears: 4.41
I don't have mine yet... Bit of a ways off for that. I've got a lot of cleaning and de-rusting to do before I get new springs in the front (I figure the rears should be good as they already sag about a half inch). It's kind of a pain finding non-A/C manual springs for the V6...
Old Sep 20, 2010 | 09:59 PM
  #137
Pillsbry10's Avatar
i have some spring tech lowering springs in mine now...car sits..a little low lol
i honestly dont see the manual springs no ac making much of a diffrence, my lowering springs were for an auto
Old Sep 20, 2010 | 10:04 PM
  #138
Engine: 2.7L V6
Axle/Gears: 4.41
That'd be the problem right there... Auto weighs more than manual. Plus you've got the spooly thing and it's associated pipes and intercooler.
Old Sep 20, 2010 | 10:30 PM
  #139
bl85c's Avatar
Car: '85 maro
I had dropsprings on mine for a while then took them off, now that the hybrid's in I may put the fronts back on just to see how it looks and if it gets alignment closer to where it should be. Not happy with it now, steering's sqirrely and looks bad.
Old Sep 21, 2010 | 04:31 PM
  #140
yeah, I couldn't believe the height difference when I mocked up an aluminum top end in my car. Almost looks like the motor is out haha. I have an iron head 2.8 on a stand along with various motors in multiple stages of completion and the weight difference is HUGE. I weighed a 3500 with the steel crank, stock exhaust manis on, minus the p/s, a/c alt, was 340lbs on the button.
Old Sep 21, 2010 | 04:42 PM
  #141
Fallen2603's Avatar
Engine: LSJ
Axle/Gears: 4.05
What's the estimate on how much the 3.4L V6 out of a 4th-Gen weighs? Just curious...
Old Sep 21, 2010 | 06:02 PM
  #142
Engine: 3.8, 3.4
probably about 350 lbs altogether.
Old Sep 21, 2010 | 08:35 PM
  #143
bl85c's Avatar
Car: '85 maro
The iron heads are about 20lbs heavier.
Old Sep 21, 2010 | 08:43 PM
  #144
Pillsbry10's Avatar
well i have a manual car with auto springs its just my drop kit was way lower than what it was supposed to be it was supposed to be a 1.75 drop...and ive got like 3 inches before the air dam and 5 before the frame(pre motor swap and turbo)
Old Sep 21, 2010 | 08:45 PM
  #145
Engine: 3.8, 3.4
I put moog springs in my rear (one spring broke) and it seems to sit lower than it should =/ Even tho they're the right springs =/
Old Sep 21, 2010 | 08:49 PM
  #146
Pillsbry10's Avatar
most of the time when people put new springs in it raises their car due to worn out stock springs lol
Old Sep 21, 2010 | 08:50 PM
  #147
Engine: 3.8, 3.4
I know right...
Old Sep 21, 2010 | 08:51 PM
  #148
Engine: 3.8, 3.4
The pic in my sig is with new springs in the rear.
Old Sep 21, 2010 | 09:03 PM
  #149
Engine: 2.7L V6
Axle/Gears: 4.41
Pillsbry, what springs did you get for yours?
Old Sep 21, 2010 | 09:06 PM
  #150
Pillsbry10's Avatar
suspension max ST...they were like the only ones i could find that had v6 lowering springs at the time
