anybody else have this hose problem?
Old Apr 1, 2010 | 02:50 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
I hate the way the coolant hoses coming up into the throttle body have such a big crimp in them. if you go to the parts store, their computer tells them to sell you a straight hose, and you bend (crimp) it
I didn't like that, so I went today and bought two gates hoses, number 28460. they are short 90 degreee hoses. I cut a little off each one, and just installed them... MUCH BETTER!!!
before and after
Old Apr 1, 2010 | 09:24 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: anybody else have this hose problem?
Thanks for the info. Just got an 88 for my son's first car, and i'm betting I will need these.
Old Apr 1, 2010 | 09:34 PM
58mark's Avatar
I''m wondering what the purpose of these coolant lines are... I suspect some type of temp sensor in the TB, but I don't know.
I don't think they are under a lot of pressure, and the crimp might not have hurt anything, but they at least look a lot better now
Old Apr 1, 2010 | 10:17 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
they are there for cold climates to keep the TB from freezing by circulating hot coolant through that small section on the bottom of the TB.
If you live in a warmer climate, you can get rid of that setup... just connect the two ports on the fitting coming from the front of the base of the intake manifold. Your TB will stay cooler and potentially help power a little, too. You could even cap the two tubes.
I used a pipe fitting that screwed into the base manifold and braized a brass 90* elbow to it and connected the tube that comes in from the side to it. Much cleaner looking!!
Old Apr 1, 2010 | 10:53 PM
58mark's Avatar
well... crap...
I'm in texas... I wish I had known that a few hours ago
thanks for the info LOL
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
