Engine won't start
Old Apr 2, 2010 | 12:45 PM
shadow644's Avatar
Car: 1987 Camaro
Engine: V-6
Engine won't start
I just got finished replacing the fuel injectors, pressure reg and the starter motor won't move I don't know what to do. please help, go easy on me I'm 16
Old Apr 2, 2010 | 07:26 PM
tr6guy's Avatar
Car: '72 Triumph TR6, '85 Camaro
Engine: 2.8 V6
Re: Engine won't start
There's not alot of information in your posting... I'm assuming it started before you did whatever work. "The starter motor won't move" ... it doesn't make any sound at all? No clicking? Cranking? Did you re-connect the battery after doing the injector work? When you turn the ignition key, do you get any dash lights? Need some more information.
Old Apr 2, 2010 | 07:41 PM
shadow644's Avatar
Car: 1987 Camaro
Engine: V-6
It's not making any Sounds at all and yea I plugged the battery in after putting in the injectors and I still getting power to everything else so I'm thinking now that a fuse broke.
Old Apr 2, 2010 | 07:46 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the CRANK 5A fuse in the fuse box... Also check to make sure no wires got pinched or anything when you put the engine back together, as this will only kill the fuse again.
Old Apr 3, 2010 | 12:39 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Battery could still be dead, when my buick century broke the battery(things on this car don't break, IT breaks THEM) anyway, it cranked fine, then cranked slower, then slower, then not at all, but weird thing was, I still had full electric, so I thought it was the starter naturally, now I couldn't pop my hood because the release cable was broken, and It was freaking snowing and I have no garage, so I wasn't about to **** with it, but point here is, even if you have full electric battery might be too low, so don't rule that out just yet
Old Apr 3, 2010 | 11:53 PM
shadow644's Avatar
Car: 1987 Camaro
Engine: V-6
I took the starter motor down to advanced auto parts and it turns out that it just went bad, so I got a new one , everything works fine now.
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
