convert to coils
Old Apr 13, 2010 | 11:45 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
convert to coils
hey everyone happy spring break
when I'm on a road trip to Florida in my 3rd good ride no problem yet "knock on wood".
well i seen a guy in north Carolina with a 1990 2.8 with a coil pack off a 3100 motor and he wired the computer up some kind of way to piggyback off his main one.
and i was wondering how it seems like a great idea but what do you need to upgrade and change.
hopefully i will see some of you guys on the way
Old Apr 14, 2010 | 12:10 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: convert to coils
First things first, is your car distributor or DIS ignition?
Old Apr 14, 2010 | 12:13 AM
Car: 1992 firebird
Engine: V6
distributor i want to which to DIS
Old Apr 14, 2010 | 12:19 AM
Engine: 3.8, 3.4
Basically you need to setup an external crank trigger on the crank pulley, and mount a crank position sensor so the ecm and or icm knows when to fire the coils, theres a couple ways to mount the trigger wheel, find an aftermarket one(they're overpriced, and I don't think theres one that is direct bolt on either) or easiest way, I believe is to get a timing cover from a 3.4 RWD camaro(93-95 v6) then off of a buick 3800 engine, the harmonic balancer, with reluctor ring and notches, from there its a matter of sensors and wiring(Which I don't know much about), but I believe your stock ECM can run it without tuning. Other than that you'll need the coils, ignition module, and a coil bracket, and imo get MSD coils and module if you really want a good ignition system.
Also if you're a good DIYer and have the tools, here is one route, if nothing else it should help point you in the direction of what you have to do:
https://www.thirdgen.org/forums/v6/5...rong-your.html
Old Apr 14, 2010 | 12:41 AM
Car: 1992 firebird
Engine: V6
sweet looks like i got a project when i get back home and I'm going to stop at a junkyard down here get a coil pack and sensors
Old Apr 14, 2010 | 01:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
3800 stuff is not a direct bolt in, and requires making reluctor wheels/discs (I'm going to have fun doing that and finding a way to mount them between the crank pulley and the damper along with mounting the CKP sensor). Everything has to come from the same engine, an FWD car or 3.4 Camaro engine.
Old Apr 14, 2010 | 03:33 PM
Engine: 3.8, 3.4
Didn't realize you had to make your own reluctor wheel using buick stuff, but in that case, why not use 3.4 RWD ****? You can put the timing cover from a 3.4 on and modify the reluctor wheel on the back of the 3.4 dampener.
Old Apr 14, 2010 | 06:55 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If it wasn't for the close quarters between the damper and the timing cover, I could just swap the reluctor rings over from a 3800 damper to the existing one (as is done for quick start modifications to older Buick 3.8L engines as in the GN) and call it a day. Besides, the 3.4 setup requires a reluctor ring be cut in either the crank pulley or a plate sandwiched between said pulley and the damper.
Old Apr 14, 2010 | 07:57 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
I was looking at the buick ignition and I don't think you'll be able to fit the sensor & reluctors under the 2.8 or 3.4 balancer. Would be nice though since that's the better ignition.
Old Apr 14, 2010 | 08:14 PM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
BL85 has a post about doing this. Even has XDF's and bin's to use.
Old Apr 14, 2010 | 09:09 PM
Engine: 3.8, 3.4
That thread is linked in my first reply.
MM2Robinson
Oct 1, 2017 09:16 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jlanz55
Sep 6, 2015 03:05 PM
