Burning oil
Old Apr 23, 2010 | 01:07 PM
aaron0991's Avatar
Burning oil
My 88 Pontiac Firebird keeps fouling out the plugs to the point where they are wet with oil. I dont see any smoke from the exhaust, any ideas?
Old Apr 23, 2010 | 01:36 PM
firebird1992's Avatar
Car: 1992 firebird
Engine: V6
Axle/Gears: 10 open 3.42
Re: Burning oil
mmm your rings are messed up maybe ? is it all the plugs or some?
Old Apr 23, 2010 | 03:52 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
Re: Burning oil
Is it oil or fuel on the plugs?
Old Apr 23, 2010 | 04:47 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Burning oil
How many miles? Some pics of the plugs would be nice. How much oil are you consuming in between changes? You could also do a compression check on all of the cylinders. I hope its nothing serious. Are you sure its gas?
Kevin
Old Apr 23, 2010 | 08:19 PM
aaron0991's Avatar
Re: Burning oil
defiantly not gas its straight oil. if its a bad case of blowby shouldn't i be seeing some type of smoke out of the exhaust.
Old Apr 28, 2010 | 04:19 PM
kevmann's Avatar
Car: 89 RS
Engine: 2.8
Re: Burning oil
Not if you have a catalytic converter. If its real bad you still would but those converters will hide a lot.
Old Apr 30, 2010 | 02:56 PM
RandogLeader's Avatar
Car: 1989 Camaro RS
Engine: 2.8L V6
Transmission: 5-Speed Manual
Re: Burning oil
Worn rings. As mentioned above: How much oil are you having to replace? I have worn rings also and it does consume oil but not enough to warrant an overhaul at this time. I will tend to see a bit of smoke when it's first started but after it warms up, it is barely noticeable. I probably replace about a quart every couple of months.
Old May 1, 2010 | 11:06 PM
84elco231's Avatar
Re: Burning oil
Compression check. If good, valve guide seals.
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
