2.8 firebird problems
Old Jun 18, 2010 | 12:01 PM
alexdavis001's Avatar
Car: 1989 camaro
Engine: 383 roller
Transmission: 5-speed
Axle/Gears: posi 373
ive got a 1988 firebird with a 2.8 that i got form my uncle he let it sat for 6 or 7 years and i got it running. it ran fine for 6 months than is stared running crappy at wot.
now its staring to miss fire and i will hardly stay running
plz help
Old Jun 18, 2010 | 12:42 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: 2.8 firebird problems
Sounds like a clogged cat converter to me, if not that, then try a tuneup, new spark plugs, wires if needed, check for vacuum leaks, replace fuel and air filter, oil change, and seafoam the engine.
Check cat converter first, and if you haven't kept up on maintenance try the tuneup, or you can do both...really should keep up on maintenance running poorly or not.
Old Jun 18, 2010 | 01:28 PM
Car: 1989 camaro
Engine: 383 roller
ive thought it was the fuel injectors so i have been running gumout to clean out the whole fuel system
i have replaced the fuel filter
ive do an oil change
and i dont have a cat anymore
Old Jun 18, 2010 | 08:49 PM
phate's Avatar
Car: 01 tj, working on 87 firebird
Engine: 2.8
Transmission: auto
Axle/Gears: dono on the bird
Any check engine lights? check your O2 sensor also check the plugs
Old Jun 18, 2010 | 08:55 PM
Car: 1989 camaro
Engine: 383 roller
i know i have a code 22 (tps) and a code 54
ive looked five of them and they looked good theres 1 i cant get to
ill check the o2 sensor tomorrow when i have light
Old Jun 18, 2010 | 10:37 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Code 54 is either a bad fuel pump relay or ECM. Code 22 means that the TPS needs to be replaced and could be the cause of your problems. If you go to the right yard, you can get a pack of TPS, IAC, and CTS or more sensors for cheap. I got one for $10.
Old Jun 19, 2010 | 12:20 AM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
EEHH...code 54? Just replace the ECM. Thats what I had to do with mine. And for sure, replace the TPS. My car sat for a good number of years as well and I am now excising the same demons.
Old Jun 19, 2010 | 05:49 PM
Car: 1989 camaro
Engine: 383 roller
if its a bad fuel pump relay,how would i know??
Old Jun 20, 2010 | 10:21 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Swap it for one of the ones next to it. That's the easiest way. They're all the same, pretty much. But, if you already have a code 54, more than likely, the ECM is the culprit, and if it has a code 54 now, it could eventually die altogether and leave you stranded.
Old Aug 21, 2010 | 01:27 PM
Car: 1989 camaro
Engine: 383 roller
now ive dont have any codes any more and i havent changed anything not miss firing any more its just not getting up and going any more. my master cylinder for my clutch went bad could this be one of my problem?
Old Jan 1, 2011 | 09:30 AM
Car: 1989 camaro
Engine: 383 roller
i changed a fuse for the head lights and it started running right
Glowsock
Jul 24, 2025 03:15 PM
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
zeitghaist
Aug 18, 2015 07:33 AM
