3.1 V6 Really a 3.8?
Old Jun 21, 2010 | 10:13 AM
Rico Sauve's Avatar
Car: 1992 Pontiac Firebird
Engine: 3.1 V-6
Transmission: 4 Speed Auto
I recently bought a new motor to replace on that was blown in my sons base model 92 firebird. the VIN # says its a 3.1 V6 we also have the window sticker from when it was new. my mom is the original owner ( one owner). But after i got the engine out and everything stripped off of it realize its not a 3.1 but something else. I think its a 3.8 because it has a L cast into the block. The 3.1 should have a T on the block. everything bolted right up to the new 3.1 except the motor mount brackets. I cant find these things anywhere. I even went junkyard shopping and the 2 firebirds that a found with the supposed to be same motor also had L on the blocks im confused can anyone out there help?
Old Jun 21, 2010 | 01:43 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 3.1 V6 Really a 3.8?
Don't know where you're getting your info, but no base model F body had a 3.8L engine in it during the third generation. If the cylinders are pointed more up than out, it's a 3.1L 60* GM V6, not a 3.8L 90* Buick V6. In 92, the Buick engines were DIS. If the engine has a distributor, it's not a 3.8.
It's possible that you bought the wrong engine. There were 2 separate versions of the 3.1 that put out equal power. The RWD blocks have the starter on the passenger's side. The FWD blocks have it on the driver's side (or where the driver's side is on the engine when installed longitudinally instead of transverse) because the transaxle housing is in the back.
Old Jun 22, 2010 | 07:22 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Pics would help...
sounds like you got a FWD block though.
Old Jun 24, 2010 | 01:36 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Easy way to tell if its a FWD, see if the starter bolts up on the same side as the old engine. If its the opposite side, you got the wrong engine.
Old Jun 24, 2010 | 08:10 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
mine has an L cast into the block, its a 3.1 outtve a 1992 camaro... my 3.4 im pretty sure has a F cast in the block its outtve a 94 camaro
Old Jun 26, 2010 | 11:28 PM
Rico Sauve's Avatar
Engine: 3.1 V-6
Thanks to all who tried to help me out with replys. After several conversations with the company I bought the new engine from (LKQ). it been figured out that i do indeed have a engine thats for a front wheel drive vehicle. They have sent me the correct one and it should be here on about Tues . again Thanks
Swapmaster
Sep 25, 2006 09:43 PM
Edde
Dec 30, 2005 01:31 AM
anesthes
Jun 15, 2005 06:22 PM
nogoshowboat
Jan 19, 2005 05:46 AM
DAN_92RS
Nov 11, 2002 02:36 PM
