Will it start?
Old Jun 25, 2010 | 04:32 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Will it start?
I'm going tomorrow to buy an 86 camaro sports coupe but the intake is off of the engine, im not sure how long the intake has been off so is there any hope for this little 2.8?
Old Jun 25, 2010 | 04:40 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Will it start?
Bring a wrench and an 18mm socket. Try to turn the engine by hand. If the hood has been down while the intake is off, it may be safe, but check it anyways. Take the fuel rail off (get fuel injector o-rings as well) and the lower plenum, and shine a flashlight in the ports, making sure there are no animals/animal nests or maple seeds (helicopters) in the ports before you try to put anything back together. Also make sure the fluids are there, but especially the oil, coolant, and trans fluid. Power steering and anything else can wait as they aren't absolutely crucial to putting the car on a trailer.
Other than that, don't break the idle air pipe when you put the engine back together. Use the vacuum routing diagram to find out where the disconnected stuff goes.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
