Location of O2 sensor on 2.8L '86 Firebird
Old Jul 25, 2010 | 09:19 PM
Keegancw's Avatar
I seem to be having trouble locating the O2 sensor on my '86 Firebird.
Could anybody post a picture of it so I can relate it to other parts of the engine? Maybe have it circled in a bright color so I know exactly what I'm looking for?
It seems silly, but I just can't seem to find it.
Thanks.
Old Jul 25, 2010 | 09:41 PM
copyfixr's Avatar
Car: 88 Camaro
Engine: 2.8v6
Transmission: 700 R4
Re: Location of O2 sensor on 2.8L '86 Firebird
If its in the same place as my Camaro it is on the Y pipe on the on the passenger side right before the cat. you should be able to see it pretty easy it you jack up the front passenger side.
Old Jul 25, 2010 | 09:42 PM
Keegancw's Avatar
Oh okay then. Thank you... I'll take a look. Problem is getting it up (I don't have any jacks or lifts)
Old Jul 25, 2010 | 09:45 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
I've changed mine with out jacking it up. You'll probably need lots of PB blaster and a 7/8in wrench.
Old Jul 25, 2010 | 09:46 PM
Keegancw's Avatar
Alright. Well now that I know where to look, it should be easier to find. Did you get underneath your car to change it?
Old Jul 25, 2010 | 10:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That's the easiest way to get at it. You'd have to go through the floorboards otherwise. You won't be able to get it out without getting the front end high enough to get some decent leverage on the thing. Which is something you will need as it's probably been in the pipe for years.
Old Jul 26, 2010 | 12:18 AM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
i found using a little bit of heat helps it break loose. a torch works nice when you have the room. just don't heat it up to much or you will have a nice sized hole in the exhaust.
Old Sep 7, 2023 | 06:42 PM
Mojanga's Avatar
Car: Pontiac Firebird
Engine: V6 2.8L
Is there only one oxygen sensor? I found the one by the converter under the car.
meeklay812
Oct 1, 2015 03:46 PM
codeysabatini
Exterior Parts for Sale
Sep 24, 2015 05:40 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BWilcox
Sep 20, 2015 12:19 PM
m00n420
Sep 11, 2015 02:39 PM
