Headers
Old Aug 4, 2010 | 05:37 PM
jakemussman's Avatar
Car: 1990 Camaro RS
Axle/Gears: 10 bolt, 3.73 Ratio, Torsen LSD
Headers
I have had the Pacesetter headers on my car for awhile now, and i was wondering what anybody else who has them did about there accesory mounting brackets that mounted to there stock manifolds? I currently dont have them on the car. Not sure if this is a problem in the long run. Thanks
Old Aug 5, 2010 | 08:45 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: Headers
Other than the air pump, everything else bolts up quite nicely (although I don't have A/C and that may cause an issue). I currently have about 50,000 km on the car and no problems.
Hope that helps.
Old Aug 8, 2010 | 02:44 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Headers
you mean the braces that went to the manifold bolts? you should be alright without them. I don't have them on my car...haven't for years.
Old Aug 8, 2010 | 05:55 PM
Car: 1990 Camaro RS
Re: Headers
Yah those are the ones I was talking about AM91. I havent been running them since I installed my headers either. I was just curious if anybody doing the same had had any troubles.
I havent yet.
Old Aug 8, 2010 | 05:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Headers
if there is a problem, you can use a threaded stud and some nuts in place of the header bolt, provided the brackets sandwich on with the header bolts.
Old Aug 8, 2010 | 06:05 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Headers
i took off countless brackets that were on my motor when i did the headers and other mods and havent had any prblems yet either, the only one i have been worried about is the bracket from the plenum to the ac compressor. since i have a 3.4 intake plenum on mine there is no where to bolt that bracket so i got rid of it.
Old Aug 8, 2010 | 10:39 PM
Car: 91 Camaro
Re: Headers
I don't have the compressor bracket on mine, either. haven't for quite a while...
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
