Engine wont run past ~3k rpms/ 30mph in 2nd and 3rd
Old Aug 8, 2010 | 08:00 PM
UDAMON's Avatar
Car: Mazda Protege5
driving fine one day when the car feels like it down shifted or bogged out. still was running but hitting the throttle wasnt doing anything until the car slowed down enough. then it ran fine up until that point again. its like an engine shut off at 120mph but its happening at around 30- or when it feels like its about to shift into 3rd.
driving in first gear you can take it to any rpm and any speed no problem
driving in 2nd and 3rd the engine will cut out at about that same point.
i dont know if its the rpms or the mphs that is causing the engine to stop running. idles and runs fine. accelerates just fine up until that certain point then just stops going. engine never stalls or anything.
any help?
3.1 v6 700r4. both seem to run strong- bad sensor perhaps??
Old Aug 9, 2010 | 01:16 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Re: Engine wont run past ~3k rpms/ 30mph in 2nd and 3rd
Is your SES light comming on? I had a similar issue and it turned out to be the knock sensor it took forever just to get to 30 mph.
Old Aug 9, 2010 | 07:15 PM
UDAMON's Avatar
Car: Mazda Protege5
no light. accelerates to 30 just fine... then stops like its hitting the speed limiter
Old Aug 9, 2010 | 11:25 PM
FAST RS's Avatar
Hmmmm..... Have you checked the timing? Is the trans slipping? Disconnect the battery for 30 mins re connect it and take it for a drive see if that changes anything.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
mfp189
Sep 27, 2015 09:25 AM
