throwout bearing
Old Aug 26, 2010 | 07:13 AM
mikey88firebird's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8
Transmission: t5
Axle/Gears: not low enough
throwout bearing
has anybody had problems getting the throwout bearing on to the fork and then on to the trans it seems like I got it on there right while the trans is off but when i get the trans installed the bearing is like hung up it wont move so It blew my slave cylinder all to hell. then got it to move and was working on my bleeding my second 2nd slave then the throwout bearing hung again and blew my slave cylinder again, any ideas ?
Old Aug 26, 2010 | 10:54 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: throwout bearing
Work it by hand towards the transmission before you put the slave in... Should align it with the input bearing retainer snout that way. If not, you need to pull the trans and make sure that there is no damage to the inner surface of the bearing and the outer surface of the input bearing retainer on the trans. Also bleed the slave cylinder in the same manner (pushing the piston into the cylinder).
Also make sure that the trans is in all the way... Could be that the slave cylinder is pushing the TO off of the trans snout and it's getting hung up on the lip at the end of the snout.
Old Aug 28, 2010 | 01:13 AM
aviator84's Avatar
You may also want to verify you installed the throw out bearing correctly. The spring clip on the end of the fork goes underneath the lip of the bearing, not over it. If you have it on wrong it could cause the slave cylinder to overextend and blow.
Old Aug 29, 2010 | 10:28 PM
Engine: 2.8
Transmission: t5
what i found was that I can move the fork by hand and it bottoms out ( the fork) about an inch before it touches the pressure plate at all. now my next question and this is going to sound stupid but itwas free is there a difference between an s10 pressure plate and a firebird pressure plate?
Old Aug 31, 2010 | 08:12 PM
Engine: 2.7L V6
Axle/Gears: 4.41
If the pressure plate was used, just go for a new clutch kit. It may be the wrong one, or it may be damaged. Either way, it's better to be sure you have new proper parts than guessing on used ones.
6speedIROC
16
Mar 15, 2023 08:33 PM
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
gord327
Oct 3, 2015 01:25 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
