OEM or High-performance Fuel pump
Old Oct 5, 2010 | 03:06 PM
xtreme_taz's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8
Transmission: Automatic
Hey all,
Quick question, I have a stock 85 Firebird with a 2.8 ltr automatic.
I think I may have to replace the fuel pump again but am curious as to whether or not I should use a OEM replacement pump like I did 5 years ago or would I be able to install a high-performance pump without any doing any upgrades to the engine?
Any input would really be helpful.
Old Oct 5, 2010 | 03:51 PM
tazextreme3's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1L V6
Re: OEM or High-performance Fuel pump
The fuel pressure regulator will control the pressure so using either should be fine. Go ahead and throw a Walbro in there.
Old Oct 6, 2010 | 06:49 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
As a side note though, unless you do some modifications you really don't need an aftermarket unit, though thye might be more reliable
Old Oct 6, 2010 | 07:51 PM
xtreme_taz's Avatar
Engine: 2.8
Thanks for the input, the biggest reason is because I replaced the fuel pump about 5 years ago with an OEM and only drove the car maybe 2000 miles since then.
I was also thinking a higher performance pump would possibly be more reliable and last longer, plus if I decide to upgrade the engine at a later point I would not have to do a fuel pump changeover then.
My biggest question at this point is should I install a 255 ltr Walbro or a 255 ltr HPF pump. I have heard several cons against Walbro but have seen nothing that actually compares the two units.
Any comments?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
