It'll idle, but dies with throttle
Old Oct 8, 2010 | 10:36 PM
steves1967's Avatar
I just picked up a 91 Firebird, the 3.1L has 81,000 miles on it. The guy I bought it from thought it had a blown head gasket. Now the ultimate plan is to build this into a True 10.5 drag car, and I already have the Procharged BBC waiting for it. But for fun I thought it would be cool to leave the 6 in it while I do all the chassis work- so here goes.
I got the car to start by moving all the wires CW 2 places- so #1 wire is on, what would be #3 position on the dist. cap. With the wires in the factory places the car just cranks but doesnt even try to start. I checked timing with the tan wire connector unplugged and it's set at 10* BTDC. I had it idling (at about 1000rpm) for 20 minutes or so- no signs of a blown head gasket (oil clean, temp about 190, no bubbles in the radiator). BUT if I try and give it any throttle it instantly dies. I checked fuel pressure- at 38lbs. So where do I go from here? The computer isnt giving me any codes either..
Thanks!
Old Oct 8, 2010 | 11:43 PM
steves1967's Avatar
Re: It'll idle, but dies with throttle
Quick update- I checked the ohms on my injectors, 3 of them were 12.5, the other 3 were 12.3 Now I'm scratching my head....
Old Oct 9, 2010 | 06:09 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
tps or clogged fuel filter maybe.
Old Oct 10, 2010 | 11:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks!
LOL I'd just put your blown BBC in it... wouldn't you rather spend time on the chassis? Not sure what kind of chassis work you'd do to create a 10.5 car while you're driving the car around! But start with check the usual: fuel/air/spark, and narrow it down; a Haynes manual will walk you through most of that.
Old Oct 10, 2010 | 05:14 PM
steves1967's Avatar
Tom- yeah I know hat would be the smart thing to do, but it sure would be more fun driving the car around with a full cage, slicks and skinnies and a chute hanging off the back of the car! BUT I put a vac gauge on the car and the needle just bounces between 14"-21" so that tells me I have internal engine problems- just gonna part it out now
92camaroJoe
Jul 29, 2023 07:57 PM
pimp2303
Jul 27, 2017 02:03 PM
bamaboy0323
Sep 3, 2015 06:07 AM
perZ
Aug 21, 2015 05:51 PM
92camaroJoe
Aug 13, 2015 06:07 AM
