that stupidass LIM coolant pipe
Old Oct 13, 2010 | 08:33 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
I believe thats where I have a major coolant leak(its spewing everywhere, and or onto my belt further compounding the issue...hard to tell if that is it for sure, but anyway, anyone know what fittings I can get to remove this stupid thing for good? And wth size wrench it is?
Old Oct 13, 2010 | 09:49 PM
project89's Avatar
Re: that stupidass LIM coolant pipe
u cant remove it if u run a thermostat , look in the sticky aftermarket pats thread there is a parts number for a dorman replacement peice and i think it wa sonly 5 bucks
Old Oct 13, 2010 | 09:52 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I believe it's a standard NPT threaded fitting, so you should be able to just get some short pipe and an elbow or something and fab something up. Or, do what I'm doing and go to the parts store and get a fitting that goes in there that you can just put a hose on. Then, see if you can get a hose that is shaped to go in the direction the original pipe did.
Problem with the thing is that blasted nylon clip that ALWAYS breaks at the worst time, and that it's a PITA to find o-rings for it. The 2.8s had a better design that was just screwed together with a double-ended fitting that went into the manifold.
Old Oct 14, 2010 | 05:45 AM
Engine: 3.8, 3.4
When I say I'm getting rid of it, I mean I'm ripping the damn thing out and putting an aftermarket type fitting in that won't fall apart, I just need to know what type of connector and thread size/type....
Old Oct 14, 2010 | 10:50 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I removed mine (along with the rest of the heater lines/hoses) and I run a t-stat with no issues.
Old Oct 14, 2010 | 08:40 PM
Engine: 2.7L V6
Axle/Gears: 4.41
I'll get you a pic of mine if it ever stops raining here. I just put it in the 3100 manifold a couple days ago to get it out of its package and out of my way on the back table. All it is is a fitting that screws into the manifold that you put a hose on. No plastic BS in the middle that will leak, no o-rings, none of that crap. Should have done it a long time ago , but I didn't.
Old Oct 14, 2010 | 08:50 PM
Engine: 3.8, 3.4
I think im just going to have to limp it over to an autozone...
Old Oct 14, 2010 | 08:57 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Don't forget to seal it when you put it in, whatever you use. Unless it's the CTS or the CTG (the term I use for the gauge sender) or the fan switch, I always use thread seal tape on the fittings because I just HATE coolant leaks.
Old Oct 14, 2010 | 10:36 PM
Engine: 3.8, 3.4
ironically I actually made it worse trying to fix it, tried to seal it with some RTV hoping it would hold long enough to get it to a parts place, but instead of leaking it now shoots out at high pressure in like 4 directions, at least 1 of which goes right onto the belt which then slings it outward....fun stuff...
sheachopper
Jul 31, 2019 11:27 AM
LT1Formula
Oct 8, 2015 08:34 PM
