2.8 Camaro Trouble
Old Oct 16, 2010 | 03:09 PM
WockaFlocka's Avatar
2.8 Camaro Trouble
Hey Ive got a 1988 2.8L v6 camaro.
This morning I go to start it up and it refuses. It just cranks and cranks but wont start. Im 16 and my dad and I tried putting a screw driver in the spark plug thing to get a spark but was unsuccesfull.
Ive got a chilton shop manual for 82-92 camaros but it isnt being much help.
If you have any suggestions or tips for me PLEASE let me know!
Thanks - Noah
Old Oct 17, 2010 | 01:07 AM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Re: 2.8 Camaro Trouble
I would think about replacing the distributor cap and rotor as a start.
Old Oct 17, 2010 | 06:40 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
A more likely suspect is the ignition coil, should also pull the ICM and have an autozone check it out for you.
Old Oct 18, 2010 | 03:24 PM
camaro18020's Avatar
Car: 1987 IROC-Z/1984 Z28/1987 V6
Engine: 350(5.7)/305(5.0)/173(2.8)
Transmission: 5speed/700R4/700R4
Axle/Gears: 4.10/3.73/3.73
My buddy has a 87 camaro 2.8. When he first got the car it ran strong. The car sat for a month and it was not running well at all. I put new plugs, wires, cap, rotor and coil and the car fired right up and ran great until the timimg chain broke. once we got the car back togther it was very hard to start and not it will start and run for 5 seconds at the most. Any ideas would be helpful. Car has 46,000 mile on it.
Old Oct 19, 2010 | 11:18 PM
donnas88camaro's Avatar
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
Thanks - Noah
Did you hit some quick start spray in the intake? Then see if it starts....
Old Oct 21, 2010 | 09:02 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
He said its not getting spark, so spraying quick start spray wont help. I am curious though.... what is the "spark plug thing"? A little more detail on that might help to diagnose this. Are you talking the plug itself, plug wire....?
Old Oct 21, 2010 | 11:03 PM
Car: 1988 Camaro
Engine: 2.8
Transmission: auto
So sorry.....i missed the no spark thing........
Old Oct 23, 2010 | 06:53 PM
lynnb1's Avatar
could be in the dist have inginiton module checked auto zone or advance does it free
Old Oct 24, 2010 | 06:00 AM
xxKing Cottonxx's Avatar
Car: 89 Firebird
Engine: 2.8L V6
i think hes talking about the spark plug wire. when my car was doing this, we checked the spark with a screw driver in the plug wire, and got no spark. so we changed the distributor cap and rotor and it started right up.
hope this helps
Old Oct 24, 2010 | 07:05 PM
rsrsrs's Avatar
Car: 90 Camaro RS
Engine: 2.8L v6
Transmission: 700
Another thing to look at is the Ignition Module. It goes under the dizzy.
Cleotiz
Jan 6, 2018 08:56 PM
E Rod
Aug 28, 2015 05:17 AM
djmarch
Aug 19, 2015 12:07 PM
86Base
Aug 8, 2015 01:34 PM
