AIR affecting O2?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
AIR affecting O2?
My '91 3.1 has an AIR pump (California) that injects air into the passenger side ex manifold. As the air is being injected ahead of the O2 sensor (after the Y) does this not adversely affect the ecu control of AFR etc.? Is air injected all the time? Later systems I believe inject the air into the cat (after the O2 sensor) which makes more sense to me but the cat injection tube is sealed off. Anyone know if the air injection could be re-rerouted to the cat or would that fail a smog test (if noticed)?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: AIR affecting O2?
My cat is capped off which seems to be standard. The only injection I see is into the manifold. In any case, at normal operating temp the air should not be injected into the manifold?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
From the factory it wasn't capped off. In any case, in closed loop air isn't blown in above the O2 sensor.
Car: check
Engine: check
Transmission: check
RBob.
Engine: 383 Carb
Transmission: 4L60
Ah, that's interesting. Hardly seems like the system is worth the effort then.
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
hence why most of us dont have it anymore
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Except in CA where I think you may be executed if you even look at it funny! Not LOL.
