My 3.1 Build Thread
Old Oct 31, 2010 | 12:23 AM
cj92firebird's Avatar
Car: 92 Pontiac Firebird
Engine: 3.1L FI
Transmission: Borg Warner T5
Axle/Gears: Stock 3.42
My 3.1 Build Thread
To start I thought I would share the story about my car. I picked the car up from a family friend for $300 dollars. Its a 92 Firebird 3.1 5 Speed Snow White. The original motor had a spun rod bearing. The guy threw a 2.8 out of an S-10 in with the deal. Well I needed a car so I changed the intake and **** from the 3.1 onto the 2.8 and put it in the car. It ran great. I had no problems with it. I replaced the flywheel, clutch, pressure plate, the whole nine yards while I was there. New rotors and wheel bearings in the front, new calipers up front new brakes all the way around it. Didn't miss a beat. I got the car going and had it on the road for about 6 weeks. Then one night I was coming down the road and a lifter failed. It blew apart and scored all the bearings in my bottom end. So here comes the rebuild:
1. Re-manufactured Crankshaft from Crankshaft Rebuilders Co.
2. Clevite main and rod bearings
3. Cloyes Timing Components
4. Melling M-Select Camshaft and Lifters Kit
5. Re-manufactured heads. (Reseated valves, new valve springs, and seals)
$600 and a lot of time later here is what the motor looks like so far.
Here is a picture of the car. This car sat in a garage for 9 years because the motor had a spun rod bearing.
PS: Sorry for the low quality pics they were taken with my phone.
Old Oct 31, 2010 | 12:54 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: My 3.1 Build Thread
The BIG question: Why didn't you start with a 3.4 short block if you are on your third engine for this car?
I am just really curious, not bashing your selection of engine at all. I know that lots of other guys are asking the same question...
Old Oct 31, 2010 | 05:13 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
I hope you cleaned the engine block REALLY good before you put everything back together, especially the oil passage for the camshaft...
Old Oct 31, 2010 | 05:19 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Probably the original 3.1 block was used, at least, that's most likely what I would do.
Old Nov 1, 2010 | 12:25 AM
Engine: 3.1L FI
I had the block hot tanked, typhoon washed, and honed. I didn't take any short cuts.
Also, I used the block I had. I don't make the most money, only a 19 year old kid, and I needed something reliable. I plan on building a motor though with a 3.4 shortblock, and some more bells and whistles. Just gotta get a better job first.
Old Nov 1, 2010 | 12:27 AM
What is "typhoon washed"?
I haven't heard that term before.
Old Nov 1, 2010 | 12:28 AM
Engine: 3.1L FI
It pretty much an enclosed pressure washer. Like a mini automatic car wash for engine blocks and **** like that.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jorlain
Oct 8, 2015 01:57 AM
86CamaroDan
Sep 29, 2015 10:08 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
