Camshaft
Old Nov 1, 2010 | 11:12 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
Camshaft
http://www.summitracing.com/parts/EDL-3790/
This Camshaft stok or cooler??
It is worth to buy it, or better than another?
The engine on the carb.
Old Nov 2, 2010 | 01:46 PM
Car: Camaro 1988
Re: Camshaft
what options stock Camshaft ????
Old Nov 2, 2010 | 10:43 PM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: Camshaft
Not a great cam. Check out what crane has or you could get what everyone else does- a delta 260 grind.
Old Nov 3, 2010 | 12:31 AM
Car: Camaro 1988
Re: Camshaft
I do not understand you!
Old Nov 3, 2010 | 08:14 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
I was thinking the same thing actually. Check out what crane has.
Old Nov 5, 2010 | 05:44 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Camshaft
Delta has a decent cam for our engines, and the melling MTC-5 cam is a decent upgrade. Ive got that one too. Check on summits site
Old Nov 5, 2010 | 07:11 PM
jensen73110's Avatar
Car: 1991 Firebird
Engine: 3.1L +bolt ons
Axle/Gears: Moser forged, 3.73, SLP posi
Re: Camshaft
If I remember right, he's going carb....
Old Nov 5, 2010 | 07:27 PM
project89's Avatar
Re: Camshaft
yeah he has more option if he ports the heads id go with a 272 cam
Old Nov 6, 2010 | 01:47 AM
Car: Camaro 1988
Re: Camshaft
Valve Springs must be changed or stock fit??
if so, these??
http://www.summitracing.com/parts/CRN-99848-12/
Old Nov 7, 2010 | 01:53 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: Camshaft
The guy's from Ukraine, he's using google translate or something like that, that's why it's not always obvious what he's trying to say. He's converting to carb too, using a performer intake for what it's worth. I've been helping him with that
It'll probably help him out if you post links to the camshafts, I'd do that but I don't know these V6 motors like y'all do
Old Nov 7, 2010 | 03:19 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
I figured as much. We get alot of people from europe asking about v6 f-bodies.
Reni-Camaro, your stock springs are fine up to .450" lift. Springs from a 3100/3400 v6 or yellow LS6 springs would be better though because of the beehive shape.
Old Nov 8, 2010 | 10:08 AM
Car: Camaro 1988
Re: Camshaft
How to understand Valve Springs Required Yes?
Thank Primetime91
I never understood, springs should be changed?
We have a small V8, and they are very expensive 305 dead $ 1000
Old Nov 8, 2010 | 04:44 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
Springs are not required, but recomended. Springs will gradually weaken over time. Here's a list of crane's cams.
Old Nov 9, 2010 | 10:40 AM
Car: Camaro 1988
Re: Camshaft
What if spring would you suggest?
I never understood these fit? http://www.summitracing.com/parts/CRN-99848-12/
I understand that my questions are stupid, but nobody else except translate.google not help me!
Прослушать
На латинице
Old Nov 10, 2010 | 07:56 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
These are better. They're out of stock now but ben will get more soon.
Old Nov 13, 2010 | 01:59 PM
Car: Camaro 1988
Re: Camshaft
CAUTION: Use only stock valve springs. Use only stock ratio rocker arms.
infa http://www.edelbrock.com/automotive_...evy_6cyl.shtml
Old Nov 13, 2010 | 04:47 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
Old Nov 18, 2010 | 03:29 AM
Car: Camaro 1988
Re: Camshaft
and?
Old Nov 18, 2010 | 12:46 PM
bl85c's Avatar
Car: '85 maro
Re: Camshaft
I don't know what you're asking. There's no reason you can't use other springs and rockers.
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
