problems with my v6 2.8L fi please help.
Old Nov 2, 2010 | 07:40 PM
cl04k3d's Avatar
I have an 88 camaro v6 2.8L FI and I have a couple problems. It basically takes forever to get up to speed but once you get up to speed it goes, also stalls sometimes at idle when in gear. You can give it all the gas you want it still takes the same amount of time to speed up.
I replaced the fuel filter/air filter/the cat isnt clogged/spark plugs/wires/distributor cap/rotor/new water pump. I have no idea why it does this but do you think if could be clogged fuel injectors? Also apparently it has low compression like 85lbs or something like that.
Old Nov 2, 2010 | 08:31 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: problems with my v6 2.8L fi please help.
Well if the compression really is low than that's most likely your problem. Low compression can be cause by bad headgaskets and bad cylinder rings, worn cylinder walls too.
If the compression isn't low than it could be that the timing is off. It could also be a worn out fuel pump or clogged injectors. Check your fuel pressure, you should have about 42psi. The first thing I would do is be sure of the compression test, if thats ok the replace the timing chain (supposed to be replaced every 25k miles) and set the timing; then test the fuel pressure, if it's low you probably need a fuel pump, if it's normal put some fuel injector cleaner in the tank; if you notice a slight improvement then you most likely need injectors.
Old Nov 2, 2010 | 08:35 PM
cl04k3d's Avatar
Thanks for the response, I'll check into that stuff.
Old Nov 2, 2010 | 08:39 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
that compression is VERY low, if I recall it should be something like either 135 or 160, can't remember which #, but it should deff be over 100. Is it that low on all cylinders??
Old Nov 2, 2010 | 08:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
IIRC, compression on the 2.8 should be over 160 PSI, having a higher CR than the 3.1, and my 3.1 had higher than 160, so... If the compression is low on one cylinder, a number of things could be wrong. Low in 2 adjacent cylinders can be a cracked head gasket/fire ring. Low in all 6 probably means the valves are loose.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Elephantismo
Feb 13, 2019 12:51 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jonas Earl
Sep 27, 2015 07:39 AM
88rscamar0
Sep 23, 2015 09:08 PM
