Getting started
Old Nov 5, 2010 | 12:52 PM
bigblack92's Avatar
Car: 1987 Camaro LS swapped, brembo brak
Engine: 2006 5.3
Transmission: 2009 AR5 from Chevy Colorado
Axle/Gears: Stock from 1999 Z/28
Getting started
Ok guys and gals, I am starting to get into my sons project car and would like some advice where to start. The story on the car is that the prev owner used it as a d/d and it died one night after idling about a minute. He said this happened several times before he quit trying. He had a mobile mech come out and work on it. They swapped in a distributor, cap, rotor, plugs, wires, fuel filter, and I think a fuel pump. After adjusting the timing it ran for 5 min then died again. At that time the mech suggested motor swap and prev owner siad "Im done" they pulled the new parts off and returned them if possible so i got the car with the dist in the drivers floorboard. I think I got it back in the right way (thumb over number 1 cyl check for press) now I am about to try and start it for the first time. If it starts for 1 min then dies where do you guys suggest to start? Ive read about checking codes but will neeed to be refreshed on that I think.
Anyone in Va Bch area interested in helping out with some work, I am willing to help out with your project including some home remodeling. I just finished a kitchen and bathroom at the house.
Old Nov 5, 2010 | 03:05 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: Getting started
You should check your fuel pressure, if you have one of these http://www.harborfreight.com/fuel-in...ter-92699.html anything below 42psi will cause a problem, also check for a clogged fuel filter.
Old Nov 5, 2010 | 03:21 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Getting started
If the car is a 90-92 year car, I'd have the ignition system checked by a dealer (I know it's big bucks, but there was a TSB on stalling and similar ignition problems related to the ignition wiring). But I'd only do this after replacing the ignition module with an AC/Delco module. The cheapo ones are just that, cheap...
Old Nov 8, 2010 | 08:21 AM
bigblack92's Avatar
Engine: 2006 5.3
Re: Getting started
Thanks for the advice. I will have my son this weekend so we will look into those when we go to the shop and get under the hood.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
