ecm ?
Old Nov 28, 2010 | 11:14 AM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
ecm ?
I'm trying to install a 3.1 into a firebird that had a 2.8,it's a 86 model,the guy I traded with was suposed to have had everything including the computer,well he said they couldn't find the computer and it was a 4 hr. drive so I took what he had.the motor is compleat with wire harness and water hoses,I have no idea what the service number or the VIN where,how hard is it going to be to get a match?where is the motor SN on a 3.1 block?i CAN'T FIND IT
Old Nov 28, 2010 | 04:56 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: ecm ?
There is no serial number on the block.
You can use your original electronics to run the 3.1 if you want.
Otherwise, you;ll be swapping to a 1227730 ECM, I'm not sure of the MEMCAL code though. You can use a MEMCAL from a FWD car, but you would need to re-program the EPROM, or use an adapter to use an aftermarket EPROM, that has the correct spark settings for your engine. The FWD 3.1 engine has different settings for the spark, due to the DIS system used on them.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
