fuel pump where is it?
Old Dec 19, 2010 | 02:18 PM
nastynate6's Avatar
Car: 1991 camaro rs. 1992 camaro z28
Engine: 3.1 liters/V6. & 305 v8
Transmission: automatic
1) i want to replace my fuel pump for my 91 camaro some ppl are telling me it might be located under the seat or in the gas tank. where is it?
2) is a v6 fuel pump different from a v8 fuel pump?
3) where is the best place to buy a fuel?
Old Dec 19, 2010 | 02:37 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
Re: fuel pump where is it?
The fuel pump is in the tank, you would have to drop the tank to replace it. Some members on here made a access door by cutting a hole in in the sheet metal above the fuel tank to remove the pump...while this is not recommended it's been done. There is a difference in v6 and v8 fuel pumps I believe they have different fuel pressure ratings. Check rock auto or even ebay for a fuel pump at a reasonable price.
Old Dec 28, 2010 | 08:55 AM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
I bought a Bosch pump off rock auto for under $100 this summer, I highly recomend it.
Old Dec 28, 2010 | 10:13 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
find a pic in here
https://www.thirdgen.org/forums/v6/5...fuel-pump.html
Old Dec 29, 2010 | 09:09 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, I highly recommend AGAINST buying a Bosch pump (but I'm a big fan of rockauto.com!). I put a Bosch one in back in '96, it died two years later. Put another one in and immediately the anti-drain-back valve was bad. That was back in the day when fuel pumps had lifetime warranties, now they don't... I wonder why... LOL
The majority of the labor (and $$ if you go to a shop) is the work involved to get the fuel tank out. If you pay $$ at a shop and they charge you more than $300, make sure they're not cutting a hole.
V8 pump flows more than a v6 pump (gph/lph).
Old Dec 29, 2010 | 10:47 PM
K-slice's Avatar
Car: 91' Firebird
Engine: 3.1 LH0 V6
There will always be a few stories about bad products from a certain brand, but they're usually the exception to the rule. Bosch products are at the high end of aftermarket parts. I personally know 2 people who have replaced their pumps with a Bosch (both own a 2.8) and neither have had any problems.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
