Where can I find info for the LC1?
Old Sep 17, 2000 | 10:27 AM
1984-Firebird-SC's Avatar
Car: 2002 Grand Am GT
Engine: 3400 V6
Transmission: Automatic
Is there anywhere on the net (or anyone here on the boards) that can give me info on the LC1 engine, just for interest's sake. Everything from tech numbers to history would be greatly appreciated! Thanks in advance!
1984 Pontiac Firebird SC
2.8L V6
Camaro Z28 mag rims and stereo
"Oh I've seen better days
The pain of these memories I cannot drive away" - Econoline Crush "Nowhere Now"
Old Sep 18, 2000 | 02:55 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LC1.. that was the 2bbl 2.8, engine code 1, right? Oh, heh, that's your motor, isn't it?
Well the same things apply for the LB8 (2.8 multiport) motors... the same upgrades are available. In your case, Edelbrock also makes a performance intake manifold and carburetor for your engine, so you could dump the E2SE smog-uretor and get some more HP out of your ride. However, I don't think the Edelbrock package is emissions legal... while you might pass emissions, if they pop the hood you might fail. Know what I mean? Depends on the state you live in.
But you can still do a major tuneup, add an exhaust, make a cold-air/ram-air intake, upgrade the spark with things like a hotter coil & ignition box, change the rear gears, upgrade your transmission, get a camshaft or roller rocker arms or both, etc. Since it's a carbureted motor, an aftermarket computer chip will "just" advance your timing, and you can do that yourself for half the price by buying a timing light.
Oh your heads are the same as the 85-89 2.8 heads.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 18, 2000 | 06:01 PM
Engine: 3400 V6
Thanks Tom! I'm not sure what the Canadian guidelines are for that kind of upgrade for me, though I'm probably not going to worry about working on it for now (well, besides the basics to keep it running ) But thanks anyway!
2.8L V6
Cornholio7979
Sep 20, 2018 02:31 AM
Brinkkl2000
Aug 4, 2018 08:29 AM
jer4251
Sep 1, 2015 09:04 AM
ambainb
Aug 29, 2015 12:43 AM
gta power
Aug 13, 2015 06:15 AM
