Knocking 2.8L
Old Sep 19, 2000 | 11:34 PM
JASONCOX's Avatar
Knocking 2.8L
ok....chain of events here....
First my Transmission was stuck in second...on the way home from the tranny shop(didn't fix yet), I high revved it once (topped it out), stopped at a light, and when I started going again it started knocking, after about 15 miles the car had almost no power in second gear and it finally shut off and wouldn't start...I had it towed home...What do you think is wrong???
[This message has been edited by JASONCOX (edited September 19, 2000).]
Old Sep 20, 2000 | 07:46 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
how many miles are on your block? And what shape is the engine in, in other words, was it raced, driven regularly, etc.
Old Sep 20, 2000 | 11:48 AM
JASONCOX's Avatar
ummm....it's the original block, about 140,000 miles. I don't race it, except for a couple times, and hardly ever do over 80. I drive it a little rough on city streets but besides that???
Old Sep 20, 2000 | 01:46 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hm, could be a bunch of things... the fact that the engine shut off bothers me. There's no knock sensor on the 2.8 (like on the v8's), so a minor knock, or hell, I'd think even a major thing, shouldn't have stopped the motor from running.
Could the timing chain have snapped? 140k miles is alot for a chain.. if the chain snapped, the valves would be free to spin "however" they wanted to, until they stopped, or were slapped by a piston into moving again. A friend of mine's 2.8 (Celebrity) had the timing chain snap, and his motor stopped. I think you can verify this with a compression tester.. about $35.
I just replaced my timing chain with Cloyes' true dual roller.. it was $90 from Summit Racing.
[edit] Oh does the motor crank when you start it? Or does the starter motor not move either? Maybe the knocking was a type of backfire, and your fuel pump is burnt out.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
[This message has been edited by TomP (edited September 20, 2000).]
Old Sep 20, 2000 | 06:14 PM
JASONCOX's Avatar
The engine cranks now....but it still knocks.... I'm in the process of replacing the lifters...
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
bplessy
Sep 30, 2015 12:14 PM
efiguy
Sep 27, 2015 01:30 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
