3.4l computer question
Old Sep 24, 2000 | 06:47 PM
RiceEater's Avatar
If i swapped out my old 2.8l for a 3.4l would I need a new computer??? I have read that all I will need is a 3.4 flywheel.
Thanks,
Mike
1986 Firebird
2.8l V6 MPFI
Cold Air Intake
K&N Filters
Next is a Warlock muffler
Old Sep 24, 2000 | 08:34 PM
Jason E's Avatar
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
You would need a new PROM. Because the PROM is what carries the fuel curve, you'd need a PROM designed to accomodate 3.4 litres, not just 2.8 litres. Hypertech or FastChip can make you a custom PROM, along with many others.
Also, you will need to change over to different injectors to accomodate the extra volume. Pods8 (where'd he go?? ) did a 2.8 to 3.4 swap in an '88 2.8 Camaro, and he actually used Ford 5.0 19lb/hr injectors. These will work, or I believe later GM 3.4 injectors would work as well.
Jason E
'89 Camaro RS 2.8
Medium Grey Metallic/AT/T-tops/all power
Hypertech chip/2 K&N filters/Modded air box
Eclipse CD/Eclipse 100x4 amp/Boston4x6 plates, 6x9 RX 3 ways/ALL Monster's goodies
Alpine Alarm w/ Keyless entry
IROC tailights/t-windows
Old Sep 24, 2000 | 08:38 PM
RenoLB8's Avatar
I'm gearing up for the 3.4 litre swap in the summer, and I"m using the 3.4 block and heads for extra displacement, and injectors for extra pressure. Other then that, I"m using the 2.8 MPFI manifolds, plenum, computer, harness, sensors, etc. for ease of installation. I'm just porting out the intake to get more air to feed the displacement. Just another option.
Reno
'88 Firebird LB8
"Cerberus"
Now: rusting on a side street til I get out of college
Plans: BUILT 3.4 motor with B&M racing tranny, Hotchkis suspension all around, lowering 1", Accel ignition all around, Splitfire plugs, 88 front bumper, ASCD Ram Air I hood, 91 GTA spoiler, formula wheels, Firehawk tires, restored interior (first on list)
Old Sep 24, 2000 | 11:26 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
would the 3.1 Prom chip work with a 3.4
Old Sep 25, 2000 | 02:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Are you sure he'd need a new prom? I mean it makes sense, definately, but I've never heard of anyone changing it. That could mean they're running lean, of course...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
