Transmission Question
Old Sep 25, 2000 | 11:57 AM
Vortex_89rs's Avatar
Usually this only happens in weather cooler than 70 degrees F. When I first start my car, it is really peppy. I get on the highway and get up to 60. Usually I run 60 right at 2000 rpm in OD. But instead of running at that, it runs anywhere from 2500 to 3250 rpm. When I put my foot down to accelerate even a little bit, the engine revs up another 500-1000 rpm and accelerates, where usually the rpms would slowly climb from 2000. Now here is the weird part: this only goes on for about 2-5 minutes. Then when I am at a constant speed or rpm, the car will act like it is shifting and go back to normal rpm (2000@60mph). It is almost like it has a 5th gear (I WISH!!!!). Could this be a problem with the torque convertor? This is really the only thing I could come up with. Any help would be appreciated!
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
Old Sep 25, 2000 | 01:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's probably your TCC (Torque Convertor Clutch) solenoid that you're feeling, and that's normal.
TCC engagement, besides happening in a certain gear & roadspeed, is also determined by your engine's coolant temperature. If your motor's cold, the TCC won't engage.
Next time that happens (high rev's), keep your right foot constant on the gas, and tap the brake lightly with your foot (enough to kick on the brake lights)- the rpm's shouldn't change.
When you feel the RPM's drop (your 5th gear), then do the same thing. Your rpm's should go back up.
What you're doing is disengaging the TCC when you hit the brake. In the first case, since the TCC never engaged, there's nothing to disengage.
The TCC disengages when ya tap the brake because it makes the trans act like a manual tranny. If you leave the clutch engaged on a 5-speed when you come to a stop, the engine stalls. Same thing would happen if your TCC remained engaged when you stopped the car.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Old Sep 25, 2000 | 09:18 PM
Thank you for clearing that up. I thought that perhaps something was wrong! I will try that out ASAP. Thanks again for the info!
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Pioneer DEH-P3000
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
redmaroz
Aug 16, 2015 11:40 PM
