More on the TV cable
Old Oct 3, 2000 | 08:24 PM
Vortex_89rs's Avatar
This is kind of an expansion of Jason E's thread - How do you know when the TV cable is adjusted correctly? Do you just have to drive it and decide it is good when it drives like you think it should?
Vman
1989 Camaro RS
2.8 V6
K&N's
700R4 tranny
Cragar Street Pro rims (old Series 30)
Pioneer DEH-P3000
Old Oct 3, 2000 | 09:03 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
Also where is it and how do u adjust it??
Old Oct 4, 2000 | 12:16 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Vortex, the cable's adjusted properly when you do the re-adjustment procedure. For kicks, you can mark where the rectangle slides into the adjuster with white-out. Then, when you're done with the re-adjustment procedure, you can see how far off your TV cable was. If the whiteout is too far forward, you were getting a harder & later shift. If the whiteout is now inside the adjuster, your trans was adjusted for low fluid pressure, which gives you an earlier & softer shift, as well as burn up the clutches faster.
IROC, the detailed explaination of adjusting the TV cable was given in the message titled "Tom P, Brian K, Graeme's, etc".
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
